TD300 is designed to drive up to three PowerMOS or IGBTs (low side and/or high side) fromCMOS or LSTTL logic signals, or pulse transformers. It i.ntegrates: .three buffers, a current sense comparator for automatic shut down if overcurrent is detected, .an Under Voltage Lockout feature to avoid .unproper output states, an operational amplifier (that allows CAD conversion for the MCU, for example). The TD300 driver provides the designer with cost, space saving, flexible and rugged solution a wide range of applications (motor driving, switching power supplies, DC/DC converters, any application requiring low or high side driving).
