2的3次方=8 聚合后是 24-3=21掩码 255.255.248.0
1.基本配置 1、基本配置 R1: sys sysname R1 int loop 0 ip add 1.1.1.1 32 int g0/0/0 ip add 192.168.12.1 24 int g0/0/1 ip add 192.168.13.1 24 q R2: sys sysname R2 int loop 0 ip add 2.2.2.2 32 int g0/0/0 ip add 192.168.12.2 24 int g0/0/1 ip add 192.168.24.2 24 q R3: sys sysname R3 int loop 0 ip add 3.3.3.3 32 int g0/0/1 ip add 192.168.13.3 24 int g0/0/0 ip add 192.168.34.3 24 int g0/0/2 ip add 192.168.35.3 24 q R4: sys sysname R4 int loop 0 ip add 4.4.4.4 32 int g0/0/1 ip add 192.168.24.4 24 int g0/0/0 ip add 192.168.34.4 24 int g0/0/2 ip add 192.168.46.4 24 q R5: sys sysname R5 int loop 0 ip add 5.5.5.5 32 int loop 1 ip add 172.16.1.1 24 int loop 2 ip add 172.16.2.1 24 int loop 3 ip add 172.16.3.1 24 int loop 4 ip add 172.16.4.1 24 int loop 5 ip add 172.16.5.1 24 int loop 6 ip add 172.16.6.1 24 int loop 7 ip add 172.16.7.1 24 int g0/0/0 ip add 192.168.56.5 24 int g0/0/1 ip add 192.168.35.5 24 q R6: sys sysname R6 int loop 0 ip add 6.6.6.6 32 int loop 1 ip add 192.168.1.1 24 int loop 2 ip add 192.168.2.1 24 int loop 3 ip add 192.168.3.1 24 int loop 4 ip add 192.168.4.1 24 int loop 5 ip add 192.168.5.1 24 int loop 6 ip add 192.168.6.1 24 int loop 7 ip add 192.168.7.1 24 int g0/0/0 ip add 192.168.56.6 24 int g0/0/1 ip add 192.168.46.6 24 q 2.建立BGP邻居 R1: [R1]bgp 100 [R1-bgp]router-id 1.1.1.1 [R1-bgp]peer 192.168.12.2 as-n 200 [R1-bgp]peer 192.168.13.3 as-n 300 R2: [R2]bgp 200 [R2-bgp]router-id 2.2.2.2 [R2-bgp]peer 192.168.12.1 as-n 100 [R2-bgp]peer 192.168.24.4 as-n 300 R3: [R3]bgp 300 [R3-bgp]router-id 3.3.3.3 [R3-bgp]peer 192.168.13.1 as-n 100 [R3-bgp]peer 192.168.35.5 as-n 400 [R3-bgp]peer 192.168.34.4 as-n 300 [R3-bgp]peer 192.168.34.4 next-hop-local 当把R1的路由条目转给R4的时候,要改变下一跳,从R5学到的路由条目转给R4的时候也要改变下一跳 为自己 R4: [R4]bgp 300 [R4-bgp]router-id 4.4.4.4 [R4-bgp]peer 192.168.24.2 as-n 200 [R4-bgp]peer 192.168.46.6 as-n 400 [R4-bgp]peer 192.168.34.3 as-n 300 [R4-bgp]peer 192.168.34.3 next-hop-local 从EBGP邻居收到的路由,发给IBGP邻居的时候,改变下一跳 但从IBGP邻居收到的路由,发给EBGP邻居的时候,不需要使用 R5: [R5]bgp 400 [R5-bgp]router-id 5.5.5.5 [R5-bgp]peer 192.168.35.3 as-n 300 [R5-bgp]peer 192.168.56.6 as-n 400 [R5-bgp]peer 192.168.56.6 next-hop-local [R5-bgp]network 172.16.1.0 24 先宣告再聚合 [R5-bgp]network 172.16.2.0 24 [R5-bgp]net 172.16.3.0 24 [R5-bgp]net 172.16.4.0 24 [R5-bgp]net 172.16.5.0 24 [R5-bgp]net 172.16.6.0 24 [R5-bgp]net 172.16.7.0 24 R6: [R6]bgp 400 [R6-bgp]router-id 6.6.6.6 [R6-bgp]peer 192.168.46.4 as-n 300 [R6-bgp]peer 192.168.56.5 as-n 400 [R6-bgp]peer 192.168.56.5 next-hop-local [R6-bgp]net 192.168.1.0 24 [R6-bgp]net 192.168.2.0 24 [R6-bgp]net 192.168.3.0 24 [R6-bgp]net 192.168.4.0 24 [R6-bgp]net 192.168.5.0 24 [R6-bgp]net 192.168.6.0 24 [R6-bgp]net 192.168.7.0 24
3.路由聚合 (1)静态聚合(可以选择跳过,直接看第二种方法,手工聚合。) [R5]ip route-static 172.16.0.0 255.255.248.0 NULL 0 [R5]bgp 400 [R5-bgp]network 172.16.0.0 21 [R6]bgp 400 [R6-bgp]aggregate 192.168.0.0 21 验证: [R1]dis bgp routing-table 虽然聚合到了,但还可以看到 172.16.0.0/21 的同时还有7条明细 现在想把明细给拒绝掉,采取团体属性。匹配 后再发送给相应的邻居。 —————— 前缀列表 [R5]ip ip-prefix noad permit 172.16.1.0 24 [R5]ip ip-prefix noad permit 172.16.2.0 24 [R5]ip ip-prefix noad permit 172.16.3.0 24 [R5]ip ip-prefix noad permit 172.16.4.0 24 [R5]ip ip-prefix noad permit 172.16.5.0 24 [R5]ip ip-prefix noad permit 172.16.6.0 24 [R5]ip ip-prefix noad permit 172.16.7.0 24 [R5]ip ip-prefix noad permit 192.168.1.0 24 [R5]ip ip-prefix noad permit 192.168.2.0 24 [R5]ip ip-prefix noad permit 192.168.3.0 24 [R5]ip ip-prefix noad permit 192.168.4.0 24 [R5]ip ip-prefix noad permit 192.168.5.0 24 [R5]ip ip-prefix noad permit 192.168.6.0 24 [R5]ip ip-prefix noad permit 192.168.7.0 24 [R5]route-policy noad permit node 10 [R5-route-policy]if-match ip-prefix noad [R5-route-policy]apply community no-advertise 不要广播 如果没匹配到就正常发送 [R5]route-policy noad permit node 20 R5调用: [R5]bgp 400 [R5-bgp]peer 192.168.35.3 route-policy noad export 有的就export过去 [R5-bgp]peer 192.168.35.3 adverise-commuity 确保可选的过渡属性能被对等体识别到 [R5]dis cu | in ip-pre 把列出来的粘贴到R6上,粘贴好后 [R6]route-policy noad permit node 10 [R6-route-policy]if-match ip-prefix noad [R6-route-policy]apply community no-advertise [R6]route-policy noad permit node 20 R6调用 [R6]bgp 400 [R6-bgp]peer 192.168.46.4 route-policy noad export 有的都export过去 [R6-bgp]peer 192.168.46.4 adverise-commuity 确保可选的过渡属性能被对等体识别到 静态聚合 R1R2 查看路由表没问题,但R3R4 一查看,还是有明细。导致部分聚合成功。静态弊端 (2)手动聚合,aggravate聚合 的方式 第一种:detail-suppressed 抑制全部明细路由 [R5]bgp 400 [R5-bgp]aggregate 172.16.0.0 21 detail-suppressed 抑制全部明细路由 [R6]bgp 400 [R6-bgp]aggregate 192.168.0.0 21 detail-suppressed 抑制全部明细路由 这种方法便捷 在R1R2R3R4查看 dis bgp routing-table OK 第二种:suppress-policy 抑制部分明细 对BGP来讲,可以发总的,也可以发指定明细+总 [R5]acl 2000 [R5-acl-basic-2000]rule permit source 172.16.1.0 0.0.0.255 [R5-acl-basic-2000]rule permit source 172.16.2.0 0.0.0.255 [R5-acl-basic-2000]rule permit source 172.16.3.0 0.0.0.255 [R5]route-policy 10 permit node 10 [R5-route-policy]if-match acl 2000 [R5]bgp 400 [R5-bgp]aggregate 172.16.0.0 21 suppress-policy 10 抑制部分明细 第三种:attribute-policy 修改路由属性 [R5]route-policy at permit node 10 [R5-route-policy]apply origin incomplete 改为引入进来的 直接应用,默认代表是所有 [R5]bgp 400 [R5-bgp]aggregate 172.16.0.0 21 suppress-policy 10 attribute-policy at
第四种:origin-policy 通过符合route-policy的具体路由来产生聚合路由,不符合时不会聚合。 需求:汇总的路由是以某一条明细路由为出发点,明细路由消失,则不会通告该条汇总路由 [R6]acl 2000 [R6-acl-basic-2000]rrule permit source 192.168.7.0 0.0.0.255 [R6]route-policy or permit node 10 [R6-route-policy]if-match acl 2000 [R6]bgp 400 [R6-bgp]aggregate 192.168.0.0 21 origin-policy or or是origin-policy的策略名称 R4上 dis bgp routing-table [R6]undo int loop7 关掉之后再查看路由表,前后对比 第五种:as-set 把起始的明细挂上去 AS号加在上面。防止环路产生 产生的这条汇总路由就可以继承明细路由的某些路径属性,从而规避 一些问题 第六种:Preference_Value —— 首选值 首先考虑的 BGP的私有属性,仅在本地路由器生效。越大越优先。s 审核编辑:黄飞
