厂商新闻
MAX14595 High-Speed, Open-Drain Capable Logic-Level Translator
The MAX14595 is a dual-channel, bidirectional logic-level translator designed specifically for low power consumption making it suitable for portable and battery-powered equipment. Externally applied voltages, VCC and VL, set the logic levels on either side of the device. A logic signal present on the VL side of the device appears as the same logic signal on the VCC side of the device, and vice-versa.
The device is optimized for the I²C bus as well as the management data input/output (MDIO) bus where often high-speed, open-drain operation is required. When TS-bar is high, the device allows the pullup to be connected to the I/O port that has the power. This allows continuous I²C operation on the powered side without any disruption while the level translation function is off.
The part is specified over the extended -40°C to +85°C temperature range, and is available in 8-bump WLP and 8-pin TDFN packages.
MAX14595关键特性
Meets Industry Standards
I²C Requirements for Standard, Fast, and High* Speeds
MDIO Open Drain Above 4MHz*
Allows Greater Design Flexibility
Down to 0.9V Operation on VL Side
Supports Above 8MHz Push-Pull Operation
Ultra-Low Power Consumption
7µA (typ) VCC Supply Current
3µA (typ) VL Supply Current
Provides High Level of Integration
Pullup Resistor Enabled with One Side Power Supply when TS-bar Is High
12kΩ (max) Internal Pullup
Low Transmission Gate RON: 17Ω (max)
Saves Space
8-Bump, 0.4mm Pitch, 0.8mm x 1.6mm WLP Package
8-Pin, 2mm x 2mm TDFN Package
MAX14595应用/使用
Devices with I²C Communication
Devices with MDIO Communication
General Logic-Level Translation
Portable and Battery-Powered Electronics
MAX14595应用电路图
