NCP1207 ic datasheet
消耗积分:0 | 格式:pdf | 大小:189 KB | 2012-02-01
分享资料个
The NCP1207 combines a true current mode modulator and a demagnetization detector to ensure full borderline/critical Conduction Mode in any load/line conditions and minimum drain voltage switching (Quasi−Resonant operation). Due to its inherent skip cycle capability, the controller enters burst mode as soon as the power demand falls below a predetermined level. As this happens at low peak current, no audible noise can be heard.
评论(0)
发评论
下载排行榜
