鸿蒙APP开发实战:【Api9】拍照、拍视频;选择图片、视频、文件工具类
鸿蒙开发过程中,经常会进行系统调用,拍照、拍视频、选择图库图片、选择图库视频、选择文件。今天就给大家分享一个工具类。
1.话不多说,先展示样式
鸿蒙
2.设计思路
根据官方提供的指南开发工具类,基础的拍照、拍视频、图库选照片、选文件不过多缀述,图库选择这里设计成集合形式,可返回图片和视频,视频展示时不显示内容,所以在工具类多加了一个获取视频缩略图的功能。
![搜狗高速浏览器截图20240326151450.png](//file1.elecfans.com/web2/M00/C5/D1/wKgZomYChGOAUaiiAADe1d8SeRY102.jpg)
**3.具体代码**
import common from '@ohos.app.ability.common';
import picker from '@ohos.file.picker';
import mediaLibrary from '@ohos.multimedia.mediaLibrary';
import wantConstant from '@ohos.ability.wantConstant';
import { MediaBean } from '../bean/MediaBean';
import { StringUtils } from '../utils/StringUtils';
  • @description 多媒体辅助类
  • @author Gwei
  • @time 2024/3/1 15:57
    export class MediaHelper {
    private readonly TAG: string = 'MediaHelper';
private mContext: common.Context;
constructor(context: common.Context) {
this.mContext = context;
  • 图库选择,返回最大数量为9的图片、视频集合
    public selectPicture(count:number): Promise< Array< MediaBean >> {
let imgList:Array< string > = [];
let mediaList:Array< MediaBean > = [];
try {
  let photoSelectOptions = new picker.PhotoSelectOptions();
  photoSelectOptions.MIMEType = picker.PhotoViewMIMETypes.IMAGE_TYPE;
  photoSelectOptions.maxSelectNumber = 9-count;
  let photoPicker = new picker.PhotoViewPicker();
  return photoPicker.select(photoSelectOptions)
    .then((photoSelectResult) = > {
      //Log.info(this.TAG, 'PhotoViewPicker.select successfully, PhotoSelectResult uri: ' + JSON.stringify(photoSelectResult));
      if (photoSelectResult && photoSelectResult.photoUris && photoSelectResult.photoUris.length > 0) {
        for (let i = 0; i < photoSelectResult.photoUris.length; i++) {
          imgList.push(photoSelectResult.photoUris[i]);
        //Log.info(this.TAG, 'PhotoViewPicker.select successfully, PhotoSelectResult uri: ' + filePath);
        return imgList;
    }).catch((err) = > {
      //Log.error(this.TAG, 'PhotoViewPicker.select failed with err: ' + err);
      return err;
    }).then(async (imgList) = > {
      for (let index = 0; index < imgList.length; index++) {
        const mediaBean = await this.buildMediaBean(imgList[index]);
        mediaList.push(mediaBean);
      return mediaList;
} catch (err) {
  //Log.error(this.TAG, 'PhotoViewPicker failed with err: ' + err);
  return Promise.reject(err);
  • 选择文件
    public selectFile(): Promise< MediaBean > {
    try {
    let documentSelectOptions = new picker.DocumentSelectOptions();
    let documentPicker = new picker.DocumentViewPicker();
    return documentPicker.select(documentSelectOptions)
    .then((documentSelectResult) = > {
    //Log.info(this.TAG, 'DocumentViewPicker.select successfully, DocumentSelectResult uri: ' + JSON.stringify(documentSelectResult));
     if (documentSelectResult && documentSelectResult.length > 0) {
       let filePath = documentSelectResult[0];
       //Log.info(this.TAG, 'DocumentViewPicker.select successfully, DocumentSelectResult uri: ' + filePath);
       return filePath;
    return err;
    }).then(async (filePath) = > {
     const mediaBean = await this.buildMediaBean(filePath);
     return mediaBean;
    } catch (err) {
  • 拍照
    public async takePhoto(context: common.UIAbilityContext): Promise< MediaBean > {
let want = {
  'uri': '',
  'action': wantConstant.Action.ACTION_IMAGE_CAPTURE,
  'parameters': {},
return context.startAbilityForResult(want)
  .then((result) = > {
    //Log.info(this.TAG, `startAbility call back , ${JSON.stringify(result)}`);
    if (result.resultCode === 0 && result.want && StringUtils.isNotNullOrEmpty(result.want.uri)) {
      //拍照成功
      //Log.info(this.TAG, 'takePhoto successfully, takePhotoResult uri: ' + result.want.uri);
      return result.want.uri;
  }).catch((error) = > {
    //Log.info(this.TAG, `startAbility error , ${JSON.stringify(error)}`);
    return error;
  }).then(async (uri: string) = > {
    const mediaBean = await this.buildMediaBean(uri);
    return mediaBean;
  • 拍视频
    public async takeVideo(context: common.UIAbilityContext): Promise< MediaBean > {
let want = {
  'uri': '',
  'action': wantConstant.Action.ACTION_VIDEO_CAPTURE,
  'parameters': {},
      //拍照成功
    return error;
    return mediaBean;
  • 封装多媒体实体类
  • @param uri 文件路径
    private async buildMediaBean(uri: string): Promise< MediaBean > {
if (StringUtils.isNullOrEmpty(uri)) {
  return null;
const mediaBean: MediaBean = new MediaBean();
mediaBean.localUrl = uri;
await this.appendFileInfoToMediaBean(mediaBean, uri);
return mediaBean;
  • 通过Uri查找所选文件信息,插入到MediaBean中
  • @param mediaBean
  • @param uri
    private async appendFileInfoToMediaBean(mediaBean: MediaBean, uri: string):Promise< MediaBean > {
  return;
let fileList: Array< mediaLibrary.FileAsset > = [];
const parts: string[] = uri.split('/');
const id: string = parts.length > 0 ? parts[parts.length - 1] : '-1';
try {
  let media = mediaLibrary.getMediaLibrary(this.mContext);
  let mediaFetchOptions: mediaLibrary.MediaFetchOptions = {
    selections: mediaLibrary.FileKey.ID + '= ?',
    selectionArgs: [id],
    uri: uri
  let fetchFileResult = await media.getFileAssets(mediaFetchOptions);
  //Log.info(this.TAG, `fileList getFileAssetsFromType fetchFileResult.count = ${fetchFileResult.getCount()}`);
  fileList = await fetchFileResult.getAllObject();
  fetchFileResult.close();
  await media.release();
} catch (e) {
  //Log.error(this.TAG, "query: file data  exception ");
if (fileList && fileList.length > 0) {
  let fileInfoObj = fileList[0];
  //Log.info(this.TAG, `file id = ${JSON.stringify(fileInfoObj.id)} , uri = ${JSON.stringify(fileInfoObj.uri)}`);
  //Log.info(this.TAG, `file fileList displayName = ${fileInfoObj.displayName} ,size = ${fileInfoObj.size} ,mimeType = ${fileInfoObj.mimeType}`);
  mediaBean.fileName = fileInfoObj.displayName;
  mediaBean.fileSize = fileInfoObj.size;
  mediaBean.fileType = fileInfoObj.mimeType;
  mediaBean.pixelmap = await this.getPixelmap(fileInfoObj)
  • @description 获取缩略图
  • @author Gwei
    getPixelmap(fileInfoObj) {
    return new Promise(function (resolve, reject) {
    fileInfoObj.getThumbnail((err, pixelmap) = > {
    if (!err) {
    resolve(pixelmap)
    }else{
    resolve('');
**4.使用方法**
async handleClick(option: MediaOption) {
let mediaBean: MediaBean;
switch (option) {
case MediaOption.TakePhoto:
mediaBean = await this.mediaHelper.takePhoto(getContext() as common.UIAbilityContext);
this.imgList.push(mediaBean)
break;
case MediaOption.TakeVideo:
mediaBean = await this.mediaHelper.takeVideo(getContext() as common.UIAbilityContext);
break;
case MediaOption.Picture:
let list: Array< MediaBean > = [];
list = await this.mediaHelper.selectPicture(this.imgList.length);
for (let i = 0; i < list.length; i++) {
this.imgList.push(list[i])
break;
case MediaOption.File:
mediaBean = await this.mediaHelper.selectFile();
this.audioList.push(mediaBean);
break;
default:
break;
工具类已经提供给大家了,希望能帮助到大家!!!
  • 相关推荐
  • 热点推荐
  • 鸿蒙
