鸿蒙OS封装【axios 网络请求】(类似Android的Okhttp3)
Okhttp.ets
 * 网络请求
import axios from '@ohos/axios'
import httpConstants from '../net/HttpConstants'
import errorCode from '../utils/errorCode'
import toast from '../utils/ToastUtils'
import router from '../utils/RouterUtils'
import SPUtils from '../utils/SPUtils'
import SpConstants from '../net/SpConstants'
axios.defaults.headers['Content-Type'] = 'application/json;charset=utf-8'
// 创建axios实例
const service = axios.create({
  baseURL:httpConstants.url,
  timeout:10000
// request拦截器
service.interceptors.request.use(async config = > {
  // 是否需要设置 token
  const access_token = await SPUtils.get(SpConstants.accessToken,"")
  if (access_token != "") {
    config.headers['Authorization'] = 'Bearer ' + access_token // 让每个请求携带自定义token 请根据实际情况自行修改
  return config
}, error = > {
  console.log(error)
  Promise.reject(error)
// 响应拦截器
service.interceptors.response.use(res = > {
  // 未设置状态码则默认成功状态
  const code = res.data.code || 200;
  // 获取错误信息
  const msg = errorCode[code] || res.data.msg || errorCode['default']
  if (code === 401) {
    toast.show("登录状态已过期,您可以继续留在该页面,或者重新登录")
    router.goNot('pages/Login')
  } else if (code === 500) {
    toast.show(msg)
    return Promise.reject(new Error(msg))
  } else if (code !== 200) {
    toast.show(msg)
    return Promise.reject('error')
  } else {
    return res
  error = > {
    console.log('err' + error)
    let { message } = error;
    if (message == "Network Error") {
      message = "后端接口连接异常";
    else if (message.includes("timeout")) {
      message = "系统接口请求超时";
    else if (message.includes("Request failed with status code")) {
      message = "系统接口" + message.substr(message.length - 3) + "异常";
    toast.show(message)
    return Promise.reject(error)
export default service
API接口调用方法
LoginAPI.ets
或+mau123789学习,是v喔
import okHttp from '../utils/Okhttp'
// 登录方法-POST方法
export function login(username, password, code, uuid) {
  const data = {
    username,
    password,
    code,
    uuid
  return okHttp({
    url: '/login',
    method: 'post',
    data: data
// 获取用户详细信息-GET方法
export function getInfo() {
  return okHttp({
    url: '/getInfo',
    method: 'get'
Login.ets页面
import {login,getInfo} from '../api/LoginAPI'
login(this.userName,this.userPwd,this.userCode,this.uuid).then(res= >{
  SPUtils.put(SpConstants.appUser,this.userName)
  SPUtils.put(SpConstants.appPwd,this.userPwd)
  SPUtils.put(SpConstants.accessToken,res.data.token)
