DS1086L datasheet
消耗积分:0 | 格式:pdf | 大小:202 KB | 2012-03-23
分享资料个
The DS1086L EconOscillator™ is a 3.3V programmableclock generator that produces a spread-spectrum(dithered) square-wave output of frequencies from130kHz to 66.6MHz. The selectable dithered outputreduces radiated-emission peaks by dithering the frequency0.5%,1%, 2%, 4%, or 8% below the programmedfrequency. The DS1086L has a power-downmode and an output-enable control for power-sensitiveapplications. All the device settings are stored in nonvolatile(NV) EEPROM memory allowing it to operate instand-alone applications.
DS1086L datasheet
评论(0)
发评论
下载排行榜
