鸿蒙OS开发案例:【Stage模型卡片】
Stage模型卡片
介绍
本示例展示了Stage模型卡片提供方的创建与使用。
用到了卡片扩展模块接口,[@ohos.app.form.FormExtensionAbility] 。
卡片信息和状态等相关类型和枚举接口,[@ohos.app.form.formInfo] 。
卡片提供方相关接口的能力接口,[@ohos.app.form.formProvider] 。
应用组件间的信息传递接口,[@ohos.app.ability.Want]。
效果预览
鸿蒙OS
鸿蒙OS
概念
Ability:Ability是应用所具备能力的抽象,也是应用程序的重要组成部分。Ability是系统调度应用的最小单元,是能够完成一个独立功能的组件。
鸿蒙OS
具体实现
1、在module.json5文件添加拓展能力,类型为卡片,并设置卡片入口srcEntrance和卡片元数据metadata。[源码参考] 例如:"metadata": [ { "name": "ohos.extension.form", "resource": "$profile:form_config" }。
 * Copyright (c) 2022 Huawei Device Co., Ltd.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
  "module": {
    "name": "entry",
    "type": "entry",
    "srcEntrance": "./ets/Application/AbilityStage.ts",
    "description": "$string:entry_desc",
    "mainElement": "MainAbility",
    "deviceTypes": [
      "default",
      "tablet",
    "deliveryWithInstall": true,
    "installationFree": false,
    "pages": "$profile:main_pages",
    "uiSyntax": "ets",
    "abilities": [
        "name": "ohos.samples.formextability.MainAbility",
        "srcEntrance": "./ets/MainAbility/MainAbility.ts",
        "description": "$string:MainAbility_desc",
        "icon": "$media:icon",
        "label": "$string:MainAbility_label",
        "visible": true,
        "skills": [
            "entities": [
              "entity.system.home",
            "actions": [
              "action.system.home",
        "startWindowIcon": "$media:icon",
        "startWindowBackground": "$color:white"
    "extensionAbilities": [
        "name": "FormAbility",
        "srcEntrance": "./ets/FormAbility/FormAbility.ts",
        "label": "$string:form_FormAbility_label",
        "description": "$string:form_FormAbility_desc",
        "type": "form",
        "metadata": [
            "resource": "$profile:form_config",
2、初始化卡片:通过实现@ohos.app.form.FormExtensionAbility卡片操作类,在卡片对象首次被创建时,初始化卡片绑定数据为空,并将卡片状态设置为就绪状态READY。 例如:onCreate(){ formBindingData.createFormBindingData({}) onAcquireFormState(want) { return formInfo.FormState.READY }。
3、配置卡片:用js编写相应的卡片,将卡片配置到resources/base/profile/form_config, [源码参考]。
  "forms": [
      "name": "widget",
      "description": "This is a service widget.",
      "src": "./js/widget/pages/index/index",
      "formConfigAbility": "ability://ohos.samples.formextability.MainAbility",
      "window": {
        "designWidth": 720,
        "autoDesignWidth": true
      "colorMode": "auto",
      "isDefault": true,
      "updateEnabled": true,
      "scheduledUpdateTime": "10:30",
      "updateDuration": 0,
      "defaultDimension": "2*4",
      "supportDimensions": [
        "2*4",
        "4*4"
  • 修改数据卡片的订阅条件的功能封装在ModifyConditionIndex.ets中,源码参考:[ModifyConditionIndex.ets]
 * Copyright (c) 2023 Huawei Device Co., Ltd.
import base from '@ohos.base';
import common from '@ohos.app.ability.common';
import dataShare from '@ohos.data.dataShare';
import formBindingData from '@ohos.app.form.formBindingData';
import formInfo from '@ohos.app.form.formInfo';
import formObserver from '@ohos.app.form.formObserver';
import formProvider from '@ohos.app.form.formProvider';
import Logger from '../../common/Logger';
import { getPersistentConditionID, savePersistentConditionID } from '../../common/StatePersistence';
const TAG = '[Sample_ModifyConditionIndex]';
let dataShareHelper: dataShare.DataShareHelper;
let conditionID = '110000';
let context: common.UIAbilityContext;
function updateCardDisplayContent(runningFormInfo: formInfo.RunningFormInfo): void {
  Logger.info(`TAG updateCardDisplayContent bundle: ${runningFormInfo.bundleName}`);
  let template: dataShare.Template = {
    predicates: {
      list: `select cityTemperature as cityTemperature, cityName as cityName from TBL00 where cityId = ${conditionID}`
    scheduler: ''
  dataShare.createDataShareHelper(context, 'datashareproxy://ohos.samples.formextability', { isProxy: true })
    .then((data: dataShare.DataShareHelper) = > {
      dataShareHelper = data;
      dataShareHelper.addTemplate('datashareproxy://ohos.samples.formextability/test', conditionID, template);
  class ProxiesType {
    key: string = '';
    subscriberId: string = '';
  let proxies = [{
    key: 'datashareproxy://ohos.samples.formextability/test',
    subscriberId: conditionID
  } as ProxiesType];
  let formData: string = '';
  Logger.info(TAG, `formData: ${JSON.stringify(formData)}`);
  let formBinding = formBindingData.createFormBindingData(formData);
  formBinding['proxies'] = proxies;
  formProvider.updateForm(runningFormInfo.formId, formBinding).then(() = > {
    Logger.info(TAG, `update Form OK formData is ${JSON.stringify(formBinding)}`);
  }).catch((err: base.BusinessError< void >) = > {
    Logger.error(TAG, `update Form Failed ${JSON.stringify(err)}`);
function modifyCondition(): void {
  let formInstanceFilterArkTS: formInfo.FormProviderFilter = {
    bundleName: 'ohos.samples.formextability',
    abilityName: 'EntryFormAbility',
    formName: 'persistentWidget',
    moduleName: 'persistentProxyForm'
  let formInstanceFilterJS: formInfo.FormProviderFilter = {
    formName: 'persistentWidgetJS',
  formObserver.getRunningFormInfosByFilter(formInstanceFilterArkTS).then((data: Array< formInfo.RunningFormInfo >) = > {
    Logger.info(TAG, `getRunningFormInfosByFilter data: ${JSON.stringify(data)}`);
    AppStorage.SetOrCreate('runningFormInfo', JSON.stringify(data));
    data.forEach(updateCardDisplayContent);
    Logger.error(TAG, `getRunningFormInfosByFilter err is ${JSON.stringify(err)}`);
  formObserver.getRunningFormInfosByFilter(formInstanceFilterJS).then((data: Array< formInfo.RunningFormInfo >) = > {
@Entry
@Component
struct IndexThi {
  @State persistentConditionID: string = '';
  @State persistentSwitchFlag: boolean = true;
  aboutToAppear() {
    context = getContext(this) as common.UIAbilityContext;
    this.persistentConditionID = getPersistentConditionID(context);
    if (typeof this.persistentConditionID !== 'string' || this.persistentConditionID === '') {
      this.persistentConditionID = '110000'
    this.persistentSwitchFlag = this.persistentConditionID.localeCompare('110000') === 0;
    Logger.debug(TAG, `persistentSwitchFlag : ${JSON.stringify(this.persistentSwitchFlag)}`);
  aboutToDisappear() {
    savePersistentConditionID(context, this.persistentConditionID);
  build() {
    Row() {
      Column({ space: 150 }) {
        Text($r('app.string.subscription_conditions'))
          .fontColor('#182431')
          .fontSize(40)
          .lineHeight(41)
          .fontWeight('Bold')
        Column() {
          Text($r('app.string.modify_subscription_conditions'))
            .fontSize(28)
            .margin({ bottom: 20 })
          Row() {
            Flex({ justifyContent: FlexAlign.SpaceEvenly }) {
              Column() {
                Text($r('app.string.city_sy'))
                  .margin({ bottom: 10 })
                Radio({ value: 'sy', group: 'modifyConditionGroup' })
                  .checked(this.persistentSwitchFlag)
                  .height(24)
                  .width(24)
                  .radioStyle({
                    checkedBackgroundColor: $r('sys.color.ohos_id_color_text_primary_activated'),
                    uncheckedBorderColor: $r('sys.color.ohos_id_color_switch_outline_off'),
                    indicatorColor: $r('sys.color.ohos_id_color_foreground_contrary')
                  .onChange((isChecked: boolean) = > {
                    Logger.info('firstRadio status is ' + isChecked);
                    if (isChecked) {
                      this.persistentConditionID = conditionID;
                      modifyCondition();
              Column() {
                Text($r('app.string.city_hz'))
                Radio({ value: 'hz', group: 'modifyConditionGroup' })
                  .checked(!this.persistentSwitchFlag)
                  .height(24)
                  .width(24)
                  .radioStyle({
                    Logger.info('secondRadio status is ' + isChecked);
                    if (isChecked) {
                      conditionID = '310000';
                      modifyCondition();
          .width('70%')
        .width('100%')
    .height('100%')
及[ModifyConditionIndex.ets]。
import { getProcessConditionID, saveProcessConditionID } from '../../common/StatePersistence';
  Logger.info(TAG, `updateCardDisplayContent bundle: ${runningFormInfo.bundleName}`);
  let proxies:Array< formBindingData.ProxyData > = [
      key: 'cityName',
      key: 'cityTemperature',
  let formBinding = formBindingData.createFormBindingData();
  let formInstanceFilter: formInfo.FormProviderFilter = {
    moduleName: 'processProxyForm'
  formObserver.getRunningFormInfosByFilter(formInstanceFilter).then((data: Array< formInfo.RunningFormInfo >) = > {
@Entry
@Component
struct IndexThi {
  @State processConditionID: string = '';
  @State processSwitchFlag: boolean = true;
  aboutToAppear() {
    this.processConditionID = getProcessConditionID(context);
    if (typeof this.processConditionID !== 'string' || this.processConditionID === '') {
      this.processConditionID = '110000'
    this.processSwitchFlag = this.processConditionID.localeCompare('110000') === 0;
    Logger.debug(TAG, `persistentSwitchFlag : ${JSON.stringify(this.processSwitchFlag)}`);
    saveProcessConditionID(context, this.processConditionID);
  build() {
    Row() {
          .fontSize(40)
          .lineHeight(41)
          .fontWeight('100%')
        Column() {
            .fontSize(28)
          Row() {
              Column() {
                  .height(24)
                  .width(24)
                  .radioStyle({
                    indicatorColor: $r('sys.color.ohos_fa_foreground_contrary'),
                    uncheckedBorderColor: $r('sys.color.ohos_id_color_switch_outline_off') })
                  .checked(this.processSwitchFlag)
                    if (isChecked) {
                      this.processConditionID = conditionID;
                      modifyCondition();
              Column() {
                  .height(24)
                  .width(24)
                  .checked(!this.processSwitchFlag)
                  .radioStyle({
                    if (isChecked) {
                      modifyCondition();
          .width('70%')
        .width('100%')
    .height('100%')
  • 使用modifyCondition来获取所有已经建立出的卡片对象。
  • 修改订阅条件:使用updateCardDisplayContent遍历所有卡片对象,并根据界面获取的订阅条件数据修改订阅条件。
    • 退出页面或应用后再次打开修改订阅条件页面,可以保留上次订阅的城市选择,源码参考:[StatePersistence.ts]
import type common from '@ohos.app.ability.common';
import fs from '@ohos.file.fs';
import Logger from './Logger';
const TAG = '[Sample_StatePersistence]';
const DATA_SIZE = 6;
const PERSISTENT_FILE_NAME = '/Persistent.txt';
function getConditionIDtoFile(context: common.Context, fileName: string): string {
  Logger.debug(TAG, 'getConditionIDtoFile call');
  if (context === undefined || context === null || typeof fileName !== 'string' || fileName === '') {
    Logger.error(TAG, `getConditionIDtoFile failed, context : ${JSON.stringify(context)}`);
    return '';
  try {
    let filePath = context.filesDir + fileName;
    let file = fs.openSync(filePath, fs.OpenMode.READ_ONLY);
    let buff = new ArrayBuffer(DATA_SIZE);
    let num = fs.readSync(file.fd, buff);
    let conditionID = String.fromCharCode.apply(null, new Uint8Array(buff));
    Logger.info(TAG, `getConditionIDtoFile : ${conditionID.length} ${conditionID}, ${num} ${filePath}`);
    fs.closeSync(file);
    return conditionID;
  } catch (err) {
    Logger.error(TAG, `getConditionIDtoFile err : ${JSON.stringify(err)}`);
    return '';
function updateConditionIDtoFile(context: common.Context, conditionID: string, fileName: string): void {
  Logger.debug(TAG, 'updateConditionIDtoFile call');
  typeof conditionID !== 'string' || conditionID === '' ||
    Logger.error(TAG, `updateConditionIDtoFile failed, conditionID : ${JSON.stringify(conditionID)}, context : ${JSON.stringify(context)}`);
    return;
  try {
    let file = fs.openSync(filePath, fs.OpenMode.READ_WRITE | fs.OpenMode.CREATE);
    let num = fs.writeSync(file.fd, conditionID);
    fs.closeSync(file);
    Logger.info(TAG, `updateConditionIDtoFile : ${conditionID}, ${num} ${filePath}`);
  } catch (err) {
    Logger.error(TAG, `updateConditionIDtoFile err : ${JSON.stringify(err)}`);
export function getPersistentConditionID(context: common.Context): string {
  return getConditionIDtoFile(context, PERSISTENT_FILE_NAME);
export function savePersistentConditionID(context: common.Context, conditionID: string): void {
  updateConditionIDtoFile(context, conditionID, PERSISTENT_FILE_NAME);
及[StatePersistence.ts]。
const PROCESS_FILE_NAME = '/Process.txt';
    return '';
  try {
    fs.closeSync(file);
    return conditionID;
  } catch (err) {
    return '';
    return;
  try {
    fs.closeSync(file);
  } catch (err) {
export function getProcessConditionID(context: common.Context): string {
  return getConditionIDtoFile(context, PROCESS_FILE_NAME);
export function saveProcessConditionID(context: common.Context, conditionID: string): void {
  updateConditionIDtoFile(context, conditionID, PROCESS_FILE_NAME);
  • 发布数据的功能封装在PublishIndex.ets及PushIndex.ets中,源码参考:[PublishIndex.ets]
import dataSharePredicates from '@ohos.data.dataSharePredicates';
import prompt from '@ohos.promptAction';
import resourceManager from '@ohos.resourceManager';
import { ValuesBucket, ValueType } from '@ohos.data.ValuesBucket';
const TAG = '[Sample_PublishIndex]';
let conditionCity: string;
let conditionID: ValueType = '110000';
let conditionData = '-30 ℃';
let shenYang: string;
let hangZhou: string;
const formInstanceFilter: formInfo.FormProviderFilter = {
function updateRDB(context: common.UIAbilityContext): void {
      Logger.info(TAG, `createDataShareHelper succeed, data :  ${JSON.stringify(data)}`);
      let dataShareHelper = data;
      let da = new dataSharePredicates.DataSharePredicates();
      da.equalTo('cityId', conditionID);
      let va: ValuesBucket = {
        cityName: conditionCity,
        cityTemperature: conditionData
      try {
        let uri = 'datashareproxy://ohos.samples.formextability/test';
        dataShareHelper.update(uri, da, va, (err, data) = > {
          if (err !== undefined) {
            Logger.info(TAG, `update error1: code: ${err.code}, message: ${err.message} `);
            prompt.showToast(
              { message: `publish err: ${JSON.stringify(err)}`, duration: 5000 });
            return;
          Logger.info(TAG, `update succeed, data : ${data}`);
          prompt.showToast(
            { message: `publish success ${conditionCity} ${conditionData}`, duration: 5000 });
        dataShareHelper.notifyChange(uri);
      } catch (err) {
        Logger.info(TAG, `update error2: code: ${err.code}, message: ${err.message} `);
      Logger.info(TAG, `createDataShareHelper error: code: ${err.code}, message: ${err.message} `);
function publish(): void {
  Logger.info(TAG, 'publish called');
    AppStorage.SetOrCreate('RunningFormInfo', JSON.stringify(data));
    prompt.showToast(
      { message: `publish err, getRunningFormInfosByFilter1 failed ${JSON.stringify(err)}`, duration: 5000 });
@Entry
@Component
struct IndexSec {
  private inputText: string = '';
  aboutToAppear() {
    let syTemp = $r('app.string.city_sy');
    let hzTemp = $r('app.string.city_hz');
    let citySy: resourceManager.Resource = {
      bundleName: syTemp.bundleName,
      moduleName: syTemp.moduleName,
    let cityHz: resourceManager.Resource = {
      bundleName: hzTemp.bundleName,
      moduleName: hzTemp.moduleName,
    shenYang = context.resourceManager.getStringSync(citySy);
    hangZhou = context.resourceManager.getStringSync(cityHz);
    conditionCity = shenYang;
  @StorageLink('RunningFormInfo') RunningFormInfo: string = '';
  @State focus: boolean = false;
  build() {
    Row() {
      Column({ space: 200 }) {
        Column({ space: 5 }) {
          Text($r('app.string.modify_publish_data'))
            .fontSize(40)
            .lineHeight(41)
            .fontWeight('100%')
        Column() {
          Column() {
            Row() {
              Text($r('app.string.selection_city'))
                .fontSize(30)
              Row() {
                Column() {
                    .fontSize(15)
                  Radio({ value: 'sy', group: 'cityGroup' })
                    .checked(true)
                    .height(24)
                    .width(24)
                    .radioStyle({
                      Logger.info(TAG, `sy status is ${JSON.stringify(isChecked)}`);
                      if (isChecked) {
                Column() {
                    .fontSize(15)
                  Radio({ value: 'hz', group: 'cityGroup' })
                    .height(24)
                    .width(24)
                    .radioStyle({
                      Logger.info(TAG, `hz status is ${JSON.stringify(isChecked)}`);
                      if (isChecked) {
                        conditionCity = hangZhou;
                .margin({ left: 20 })
              .margin({ left: 10 })
            Row() {
              Text($r('app.string.input_temperature'))
                .fontSize(30)
                .width(200)
                .height(60)
              TextInput({ text: '-30' })
                .fontSize(20)
                .fontColor($r('sys.color.ohos_id_color_text_primary'))
                .width(100)
                .height(40)
                .type(InputType.Normal)
                .borderRadius(16)
                .backgroundColor($r('sys.color.ohos_id_color_text_field_sub_bg'))
                .onChange((text) = > {
                  this.inputText = text;
              Text('℃')
                .fontSize(30)
                .height(60)
          .alignItems(HorizontalAlign.Start)
          Button() {
            Text($r('app.string.published_data'))
              .fontColor($r('sys.color.ohos_id_color_foreground_contrary'))
              .fontSize($r('sys.float.ohos_id_text_size_button1'))
              .fontWeight(FontWeight.Bold)
          .width(220)
          .height(40)
          .type(ButtonType.Capsule)
          .margin({ top: 20 })
          .borderRadius($r('sys.float.ohos_id_corner_radius_button'))
          .backgroundColor($r('sys.color.ohos_id_color_component_activated'))
          .onClick(() = > {
            if (Number(this.inputText) >= -40 && Number(this.inputText) <= 60) {
              Logger.info(TAG, `correct temperature is ${this.inputText}`);
              conditionData = this.inputText + ' ℃';
              publish();
              updateRDB(context);
            } else {
              Logger.info(TAG, `incorrect temperature is ${this.inputText}`);
              prompt.showToast({ message: 'Please enter the correct value from -40 to 60', duration: 5000 });
        .height('30%')
      .width('100%')
    .height('100%')
及[PushIndex.ets]。
const TAG = '[Sample_PushIndex]';
let uri = ('datashareproxy://ohos.samples.formextability');
let conditionCity = '';
  dataShare.createDataShareHelper(context, uri, { isProxy: true }, (err, dataHelper) = > {
    Logger.info(TAG, `dataShareHelper err: ${err}`, `data: ${dataShareHelper}`);
    dataShareHelper = dataHelper;
      Logger.error(TAG, `createDataShareHelper error code: ${err.code}`, `message: ${err.message} `);
      prompt.showToast({ message: 'createDataShareHelper:' + err.message, duration: 5000 });
    } else {
      let publishedItemData: Array< dataShare.PublishedItem > = [
        { key: 'cityName', data: JSON.stringify(conditionCity), subscriberId: conditionID },
        { key: 'cityTemperature', data: JSON.stringify(conditionData), subscriberId: conditionID }
      dataShareHelper.publish(publishedItemData, 'ohos.samples.formextability').then((data: Object) = > {
        Logger.info(TAG, `publish success, data is ${JSON.stringify(data)}`);
        prompt.showToast(
        Logger.error(TAG, `publish error: ${JSON.stringify(err)}`);
        prompt.showToast({ message: `publish err: ${JSON.stringify(err)}`, duration: 5000 });
    prompt.showToast(
      { message: `publish err, getRunningFormInfosByFilter failed ${JSON.stringify(err)}`, duration: 5000 });
@Entry
@Component
struct IndexSec {
  @StorageLink('runningFormInfo') runningFormInfo: string = '';
  aboutToAppear() {
    conditionCity = context.resourceManager.getStringSync($r('app.string.city_sy'));
  build() {
    Row() {
            .fontSize(40)
            .lineHeight(41)
            .fontWeight('100%')
        Column() {
          Column() {
            Row() {
                .fontSize(30)
              Row() {
                Column() {
                    .fontSize(15)
                    .checked(true)
                    .height(24)
                    .width(24)
                    .radioStyle({
                      if (isChecked) {
                Column() {
                    .fontSize(15)
                    .height(24)
                    .width(24)
                    .radioStyle({
                      if (isChecked) {
                        conditionCity = context.resourceManager.getStringSync($r('app.string.city_hz'));
            Row() {
                .fontSize(30)
                .width(200)
                .height(60)
                .fontSize(20)
                .width(100)
                .height(40)
                .borderRadius(16)
                  conditionData = text;
              Text('℃')
                .fontSize(30)
                .height(60)
          Button() {
          .height(40)
          .width(220)
          .onClick(() = > {
            if (Number(conditionData) >= -40 && Number(conditionData) <= 60) {
              Logger.info(TAG, `correct temperature is ${conditionData}`);
              publish();
            } else {
              Logger.info(TAG, `incorrect temperature is ${conditionData}`);
        .alignItems(HorizontalAlign.Center)
        .height('30%')
      .width('100%')
    .height('100%')
更多鸿蒙开发应用知识已更新gitee.com/li-shizhen-skin/harmony-os/blob/master/README.md参考前往。
  • [PublishIndex.ets]使用updateRDB来修改rdb数据库中的对应数据。
  • [PushIndex.ets]使用getRunningFormInfosByFilter获取已经建立出的卡片对象,并使用updateCardDisplayContent遍历所有卡片对象,使用createDataShareHelper创建DataShareHelper对象,并根据界面获取的数据信息使用publish进行数据的发布以实现发布数据的功能
  • 在dataShare模块中,建立rdb数据库,并提供对应update方法。
    • 在onCreate中初始化数据库中的数据。
    • 在update中实现对应的数据更新方法。
