可靠性维修术语
可靠性分析
7人已加入
  修理的产品 repaired itemyn
  不修理的产品 non-repaired itemyn
  服务 serviceyn3中国可靠性资源网
  规定功能 required functionyn
  时刻 instant of timeyn
  时间区间 time intervalyn
  持续时间 time durationyn
  累积时间 accumulated timeyn
  量度 measureyn
  工作 operationyn
  修改(对产品而言) modification (of an item)yn
  效能 effectivenessyn
  固有能力 capabilityyn
  耐久性 durabilityyn
  可靠性 reliabilityyn
  维修性 maintainabilityyn
  维修保障性 maintenance support performanceyn
  可用性 availabilityyn
  可信性 dependabilityyn
  失效 failureyn
  致命失效 critical failureyn
  非致命失效 non-critical failureyn
  误用失效 misuse failureyn
  误操作失效 mishandling failureyn
  弱质失效 weakness failureyn
  设计失效 design failureyn
  制造失效 manufacture failureyn
  老化失效;耗损失效 ageing failure; wear-out failureyn
  突然失效 sudden failureyn
  渐变失效;漂移失效 gradual failure; drift failureyn
  灾变失效 cataleptic failureyn
  关联失效 relevant failureyn
  非关联失效 non-relevant failureyn
  独立失效 primary failureyn
  从属失效 secondary failureyn
  失效原因 failure causeyn
  失效机理 failure mechanismyn
  系统性失效;重复性失效 systematic failure; reproducible failureyn
  完全失效 complete failureyn
  退化失效 degradation failureyn
  部分失效 partial failureyn
  故障 faultyn
  致命故障 critical faultyn
  非致命故障 non-critical faultyn
  重要故障 major faultyn
  次要故障 minor faultyn
  误用故障 misuse faultyn
  误操作故障 mishandling faultyn
  弱质故障 weakness faultyn
  设计故障 design faultyn
  制造故障 manufacturing faultyn
  老化故障;耗损故障 ageing fault; wear-out faultyn
  程序敏感故障 programme-sensitive faultyn
  数据敏感故障 data-sensitive faultyn
  完全故障;功能阻碍故障 complete fault; function-preventing faultyn
  部分故障 partial faultyn
  持久故障 persistent faultyn
  间歇故障 intermittent faultyn
  确定性故障 determinate faultyn
  非确定性故障 indeterminate faultyn
  潜在故障 latent faultyn
  系统性故障 systematic faultyn
  故障模式 fault modeyn
  故障产品 faulty itemyn
  差错 erroryn
  失误 mistakeyn
  工作状态 operating stateyn
  不工作状态 non-operating stateyn
  待命状态 standby stateyn
  闲置状态;空闲状态 idle state; free stateyn
  不能工作状态 disable state; outageyn
  外因不能工作状态 external disabled stateyn
  不可用状态;内因不能工作状态 down state; internal disabled stateyn
  可用状态 up timeyn
  忙碌状态 busy stateyn
  致命状态 critical stateyn
  维修 maintenanceyn
  维修准则 maintenance philosophyyn
  维修方针 maintenance policyyn
  维修作业线 maintenance echelon; line of maintenanceyn
  维修约定级 indenture level (for maintenance)yn
  维修等级 level of maintenanceyn
  预防性维修 preventive maintenanceyn
  修复性维修 corrective maintenanceyn
  受控维修 controlled maintenanceyn
  计划性维修 scheduled maintenanceyn
  非计划性维修 unscheduled maintenanceyn
  现场维修 on-site maintenance; in sits maintenance; field maintenanceyn
  非现场维修 off-site maintenanceyn
  遥控维修 remote maintenanceyn
  自动维修 automatic maintenanceyn
  逾期维修 deferred maintenanceyn
  基本的维修作业 elementary maintenance activityyn
  维修工作 maintenance action; maintenance taskyn
  修理 repairyn
  故障识别 fault recognitionyn
  故障定位 fault localizationyn
  故障诊断 fault diagnosisyn
  故障修复 fault correctionyn
  功能核查 function check-outyn
  恢复 restoration; recoveryyn
  监测 supervision; monitoringyn
  维修的实体 maintenance entityyn
  影响功能的维修 function-affecting maintenanceyn
  妨碍功能的维修 function-preventing maintenanceyn
  减弱功能的维修 function-degrading maintenanceyn
  不影响功能的维修 function-permitting maintenanceyn
  维修时间 maintenance timeyn
  维修人时 MMH; maintenance man-houryn
  实际维修时间 active maintenance timeyn
  预防性维修时间 preventive maintenance timeyn
  修复性维修时间 corrective maintenance timeyn
  实际的预防性维修时间 active preventive maintenance timeyn
  实际的修复性维修时间 active corrective maintenance timeyn
  未检出故障时间 undetected fault timeyn
  管理延迟(对于修复性维修) administrative delayyn
  后勤延迟 logistic delayyn
  故障修复时间 fault correction timeyn
  技术延迟 technical delayyn
  核查时间 check-out timeyn
  故障诊断时间 fault diagnosis timeyn
  故障定位时间 fault localization timeyn
  修理时间 repair timeyn
  工作时间 operating timeyn
  不工作时间 non-operating timeyn
  需求时间 required timeyn
  无需求时间 non-required timeyn
  待命时间 standby timeyn
  闲置时间 idle time; free timeyn
  不能工作时间 disabled timeyn
  不可用时间 down timeyn
  累积不可用时间 accumulated down timeyn
  外因不能工作时间 external disabled time; external loss timeyn
  可用时间 up timeyn
  首次失效前时间 time to first failureyn
  失效前时间 time to failureyn
  失效间隔时间 time between failuresyn
  失效间工作时间 operating time between failuresyn
  恢复前时间 time to restoration; time to recoveryyn
  使用寿命 useful lifeyn
  早期失效期 early failure periodyn
  恒定失效密度期 constant failure intensity periodyn
  恒定失效率期 constant failure rate periodyn
  耗损失效期 wear-out failure periodyn
  瞬时可用度 instantaneous availabilityyn
  瞬时不可用度 instantaneous unavailabilityyn
  平均可用度 mean availabilityyn
  平均不可用度 mean unavailabilityyn
  渐近可用度 asymptotic availabilityyn
  稳态可用度 steady-state availabilityyn
  渐近不可用度 asymptotic unavailabilityyn
  稳态不可用度 steady-state unavailabilityyn
  渐近平均可用度 asymptotic mean availabilityyn
  渐近平均不可用度 asymptotic mean unavailabilityyn
  平均可用时间 mean up timeyn
  平均累积不可用时间 mean accumulated down timeyn
  可靠度 reliabilityyn
  瞬时失效率 instantaneous failure rateyn
  平均失效率 mean failure rateyn
  瞬时失效密度 instantaneous failure intensityyn
  平均失效密度 mean failure intensityyn
  平均首次失效前时间 MTTFF; mean time to first failureyn
  平均失效前时间 MTTF; mean time to failureyn
  平均失效间隔时间 MTBF; mean time between failuresyn
  平均失效间工作时间 MOTBF; mean operating time between failureyn
  失效率加速系数 failure rate acceleration factoryn
  失效密度加速系数 failure intensity acceleration factoryn
  维修度 maintainabilityyn
  瞬时修复率 instantaneous repair rateyn
  平均修复率 mean repair rateyn
  平均维修人时 mean maintenance man-houryn
  平均不可用时间 MDT; mean down timeyn
  平均修理时间 MRT; mean repair timeyn
  P-分位修理时间 P-fractile repair timeyn
  平均实际修复性维修时间 mean active corrective maintenance timeyn
  平均恢复前时间 MTTR; mean time to restorationyn
  故障识别比 fault coverageyn
  修复比 repair coverageyn
  平均管理延迟 MAD; mean administrative delayyn
  P-分位管理延迟 P-fractile administrative delayyn
  平均后勤延迟 MLD; mean logistic delayyn
  P-分位后勤延迟 P-fractile logistic delayyn
  验证试验 compliance testyn
  测定试验 determination testyn
  实验室试验 laboratory testyn
  现场试验 field testyn
  耐久性试验 endurance testyn
  加速试验 accelerated testyn
  步进应力试验 step stress testyn
  筛选试验 screening testyn
  时间加速系数 time acceleration factoryn
  维修性检验 maintainability verificationyn
  维修性验证 maintainability demonstrationyn
  观测数据 observed datayn
  试验数据 test datayn
  现场数据 field datayn
  基准数据 reference datayn
  冗余 redundancyyn
  工作冗余 active redundancyyn
  备用冗余 standby redundancyyn
  失效安全 fail safeyn
  故障裕度 fault toleranceyn
  故障掩盖 fault maskingyn
  预计 predictionyn
  可靠性模型 reliability modelyn
  可靠性预计 reliability predictionyn
  可靠性分配 reliability allocation; reliability apportionmentyn
  故障模式与影响分析 FMEA; fault modes and effects analysisyn
  故障模式影响与危害度分析 FMECA; fault modes, effects and criticality analysisyn
  故障树分析 FTA; fault tree analysisyn
  应力分析 stress analysisyn
  可靠性框图 reliability block diagramyn
  故障树 fault treeyn
  状态转移图 state-transition diagramyn
  应力模型 stress modelyn
  故障分析 fault analysisyn
  失效分析 failure analysisyn
  维修性模型 maintainability modelyn
  维修性预计 maintainability predictionyn
  维修树 maintenance treeyn
  维修性分配 maintainability allocation; maintainability apportionmentyn
  老练 burn inyn
  可靠性增长 reliability growthyn
  可靠性改进 reliability improvementyn
  可靠性和维修性管理 reliability and maintainability managementyn
  可靠性和维修性保证 reliability and maintainability assuranceyn
  可靠性和维修性控制 reliability and maintainability controlyn
  可靠性和维修性大纲 reliability and maintainability programmeyn
  可靠性和维修性计划 reliability and maintainability planyn
  可靠性和维修性审计 reliability and maintainability audityn
  可靠性和维修性监察 reliability and maintainability surveillanceyn
  设计评审 design reviewyn
  真实的 trueyn
  预计的 predictedyn
  外推的 extrapolatedyn
  估计的 estimatedyn
  固有的 intrinsic; inherentyn
  使用的 operationalyn
  平均的 meanyn
  P-分位 P-fractileyn
  瞬时的 instantaneousyn
  稳态的 steady state
