eeDesigner
2024-04-18
4812
加入交流群
NXP HoverGames无人机系统解决方案是单一、模块化、灵活的NXP开发平台,基于RDDRONE-FMUK66飞行管理单元。KIT-HGDRONEK66无人机套件是一款完整的碳纤维四轴飞行器无人机,提供了评估RDDRONE-FMUK66所需的机械和其他元件。RDDRONE-FMUK66飞行管理单元增加了BLDC电机控制功能和一个机械平台,可以安装在无人机套件上。KIT-HGDRONEK66是DIY专业开发套件,需要进行较为复杂的组装且不含软件。
RDDRONE-FMUK66是一款NXP飞行控制器,采用以前称为NXPhlite FMU的180MHz Kinetis K66。RDDRONE-FMUK66是一个与Dronecode.org和PX4.io软件兼容的实验性飞行管理单元,广泛采用PX4研究用和商用无人机平台。RDDRONE-FMUK66 FMU包含DCD-LZ调试适配器和电缆(带Segger J-Link Mini EDU)、RC无线电适配器电缆、M8N GPS模块(带蜂鸣报警器和武装开关),以及用于3S电池的电源模块。
需要使用HGD-TELEM915(美洲)和HGD-TELEM433(欧洲)遥测无线电设备,才能发挥该套件的全部功能。根据位置的不同,用户需要915MHz或433MHz设置。
特性
RDDRONE-FMUK66 Reference Design Board
Proven business-friendly opensource software with available enterprise support: PX4, QGroundControl
Supports all airframes
Open and flexible for development
High-bandwidth interfaces
Included in complete reference drone kit KIT-HGDRONEK66
Operate pre-planned GPS waypoint missions
Use DroneCodeSDK co-operating with an NXP i.MX, S32x or other companion computer running Linux, ROS, and MAVROS
MAVLink telemetry to ground station
Supports RTK GPS
UAS Traffic management (UTM) services through Airmap platform SDK
KIT-HGDRONEK66 Drone Kit
Carbon fiber mechanical frame approx. 500mm diagonal size
150mm x 150mm large top and bottom plate for mounting electronics
Dual 10mm diameter rod x 60mm rail mounting system
No software is provided by NXP
Supports expansion using a Linux companion computer for Vision, ROS, Artificial Intelligence
Supports connection to Rapid IoT with add-on adapter board
HGD-TELEM433 and HGD-TELEM915 Peripheral
For drone kit communications to QGroundControl software
Each part number includes two radios, one for PC (USB) and one for on-drone (Serial)
