两段式状态机不可能完成的任务
FPGA/ASIC技术
206人已加入
  最近折腾状态机,发现一个小任务对于两段式状态机写法是不可能完成的。这个小任务很简单,先看用一段式状态机实现的代码:
  module test(
  clk,rst_n,
  din,dout
  input clk;
  input rst_n;
  input din;
  output[3:0] dout;
  parameter IDLE = 3'd0;
  parameter STA1 = 3'd1;
  //一段式写法
  reg[2:0] cstate;
  reg[3:0] cnt;
  always @(posedge clk or negedge rst_n)
  if(!rst_n) cstate <= IDLE;
  else begin
  case(cstate)
  IDLE: begin
  cnt <= 4'd0;
  if(din) cstate <= STA1;
  else cstate <= IDLE;
  end
  STA1: begin
  cnt <= cnt+1'b1;
  if(cnt == 4'd10) cstate <= IDLE;
  else cstate <= STA1;
  end
  default: cstate <= IDLE;
  endcase
  end
  assign dout = cnt;
  endmodule
  同样的,用三段式状态机也能够实现这个功能:
  //三段式写法
  reg[2:0] cstate,nstate;
  reg[3:0] cnt;
  else cstate <= nstate;
  always @(cstate or din or cnt) begin
  case(cstate)
  IDLE: if(din) nstate = STA1;
  else nstate = IDLE;
  STA1: if(cnt == 4'd10) nstate = IDLE;
  else nstate = STA1;
  default: nstate = IDLE;
  endcase
  end
  if(!rst_n) cnt <= 4'd0;
  else begin
  case(nstate)
  IDLE: cnt <= 4'd0;
  STA1: cnt <= cnt+1'b1;
  default: ;
  endcase
  end
  严格来看,上面的三段式状态机相比于一段式会滞后一个时钟周期。但是我们的重点不在这里,大家大可以不必钻这个牛角尖。另外,这个实例实现的功能本身也没有什么意义,当然也是可以用别的更简单(不需要状态机)的方式实现,但是你可以想象成这是实际应用中状态机各种复杂输出的一部分。
  而如果大家希望用两段式状态机实现这个功能,或许会这么写:
  //两段式写法
  reg[3:0] cnt;
  case(cstate)
  IDLE: begin
  cnt = 4'd0;
  else nstate = IDLE;
  end
  STA1: begin
  cnt = cnt+1'b1;
  else nstate = STA1;
  end
  endcase
  end
  如果大家有兴趣对三中代码方式都做一下仿真,会发现一些有意思的问题,尤其两段式状态机最终根本无法退出STA1,计数器cnt也会死在那里。究其根本原因,可大有学问。在编译工程后,出现了数条类似下面的warning:
  Warning: Found combinational loop of 2 nodes
  Warning: Node "Add0~2"
  Warning: Node "cnt~9"
  何为combinational loop?让handbook来解释吧,看不懂英文的可别怪我~_~
  Combinational loops are among the most common causes of instability and unreliability in digital designs. They should be avoided whenever possible. In a synchronous design, feedback loops should include registers. Combinational loops generally violate synchronous design principles by establishing a direct feedback loop that contains no registers. For example, a combinational loop occurs when the left-hand side of an arithmetic expression also appears on the right-hand side in HDL code. A combinational loop also occurs when you feed back the output of a register to an asynchronous pin of the same register through combinational logic, as shown in Figure 5–1.
锁存器
  没有寄存器打一拍的这种combinational loop(组合环)是一种不推荐的设计方式,就如两段式状态机所实现的效果,甚至最终无法实现功能要求。同样的功能,一段式和三段式状态机之所以能够解决这个问题,就是避免了在纯组合逻辑中涉及这个反馈逻辑。在初学verilog时,我们常提的latch(锁存器),其实也是combinational loop的一个特例。
