基于FPGA的中文字符显示的VHDL程序
FPGA/ASIC技术
211人已加入
  --文件名:lcd_driver.vhd。
  --功能:FGAD驱动LCD显示中文字符“年”。
  --最后修改日期:2004.3.24。
  library IEEE;
  use IEEE.STD_LOGIC_1164.ALL;
  use IEEE.STD_LOGIC_ARITH.ALL;
  use IEEE.STD_LOGIC_UNSIGNED.ALL;
  entity lcd_driver is
  Port ( clk : in std_logic; --状态机时钟信号,同时也是液晶时钟信号,其周期应该满足液晶数据的建立时间
  reset:in std_logic;
  lcdda : out std_logic; --寄存器选择信号
  lcdrw : out std_logic; --液晶读写信号
  lcden : out std_logic; --液晶时钟信号
  data : out std_logic_vector(7 downto 0)); --液晶数据信号
  end lcd_driver;
  architecture Behavioral of lcd_driver is
  type state is (set_dlnf,set_cursor,set_dcb,set _cgram,write _cgram,set_ddram,write_data);
  signal current_state:state;
  type ram2 is array(0 to 7) of std_logic_vector(7 downto 0);
  constant cgram:ram2:=(("00001000"),("00001111"),("00010010"),
  ("00001111"),("00001010"),("00011111"),("00000010"),("00000010"));--年字符数据存储器
  signal clkk : std_logic;
  begin
  lcden <= clk ; --液晶时钟信号
  lcdrw <= '0' ; --写数据
  control:process(clk,reset,current_state) --液晶驱动控制器
  variable cnt1: std_logic_vector(2 downto 0);
  begin
  if reset='0'then
  current_state<=set_dlnf;
  cnt1:=(others => '1');
  lcdda<='0';
  elsif rising_edge(clk)then
  current_state <= current_state ;
  lcdda <= '0';
  case current_state is
  when set_dlnf=>
  data<="00111100";--3cH
  current_state<=set_cursor;
  when set_cursor=>
  data<="00000110";--06H
  current_state<=set_dcb;
  when set_dcb=>
  data<="00001111";--0fH
  current_state<=set_ cgram;
  when set_ cgram=>
  data<="01000000";--40H
  current_state<=write_ cgram;
  when write_ cgram=> --向CGRAM中写入“年”
  lcdda<='1';
  cnt1:=cnt1+1;
  data<=cgram(conv_integer(cnt1));
  if cnt1 = "111" then
  current_state<=set_ddram;
  end if;
  when set_ddram=> --从第一行的起始地址开始显示
  data<="10000000";--80H
  current_state<=write_data;
  when write_data=>
  lcdda<='1';
  data<="00000000"; --写入字符“年”
  when others => null;
  end case;
  end if;
  end process;
  end Behavioral;
