FPGA驱动LED静态显示和动态显示的VHDL程序
FPGA/ASIC技术
211人已加入
 例1:FPGA驱动LED静态显示
  --文件名:decoder.vhd
  --功能:译码输出模块,LED为共阳接法
  --最后修改日期:2004.3.24
  library IEEE;
  use IEEE.STD_LOGIC_1164.ALL;
  use IEEE.STD_LOGIC_ARITH.ALL;
  use IEEE.STD_LOGIC_UNSIGNED.ALL;
  entity decoder is
  Port (seg:in std_logic_vector(3 downto 0 ); --四位二进制码输入
  q3:out std_logic_vector(6 downto 0) ); --输出LED七段码
  end decoder;
  architecture Behavioral of decoder is
  begin
  process(seg)
  begin
  case seg is
  when "0000" => q3<="0000001";--0
  when "0001" => q3<="1001111";--1
  when "0010" => q3<="0010010";--2
  when "0011" => q3<="0000110";--3
  when "0100" => q3<="1001100" --4
  when "0101" => q3<="0100100";--5
  when "0110" => q3<="0100000";--6
  when "0111" => q3<="0001111";--7
  when "1000" => q3<="0000000";--8
  when "1001" => q3<="0000100";--9
  when others => q3<="1111111";
  end case;
  end process;
  end Behavioral;
例2:FPGA驱动LED动态显示(4位)
  --文件名:dynamic.vhd。
  --功能:动态扫描模块,位选信号高电平有效。
  --最后修改日期:2004.3.24。
  library IEEE;
  entity dynamic is
  Port ( clk : in std_logic;
  reset: in std_logic;
  din1 : in std_logic_vector(6 downto 0); --译码后的数据信号1(4位2进制数据
  通过例1中的decoder模块译码得到din1,din2,din3,din4)
  din2 : in std_logic_vector(6 downto 0); --译码后的数据信号2
  din3 : in std_logic_vector(6 downto 0); --译码后的数据信号3
  din4 : in std_logic_vector(6 downto 0); --译码后的数据信号4
  shift: out std_logic_vector(3 downto 0); --位选信号
  bus4 : out std_logic_vector(6 downto 0)); --数据信号
  end dynamic;
  architecture Behavioral of dynamic is
  signal scan_clk:std_logic_vector(1 downto 0);
  begin
  process(clk,scan_clk,reset) --分频进程
  variable scan:std_logic_vector(17 downto 0);
  begin
  if reset='1' then
  scan:="000000000000000000";
  scan_clk<="00";
  elsif clk'event and clk='1'then
  scan:=scan+1;
  end if;
  scan_clk<=scan(17 downto 16);
  end process;
  process(scan_clk,din1,din2,din3,din4) --扫描进程
  begin
  case scan_clk is
  when "00"=>
  bus4<=din1;
  shift<="0001";
  when "01"=>
  bus4<=din2;
  shift<="0010";
  when "10"=>
  bus4<=din3;
  shift<="0100";
  when "11"=>
  bus4<=din4;
  shift<="1000";
  when others=> bus4<="0000000";shift<="0000";
  end case;
  end process;
  end Behavioral;
