在使用Trion乘法器可能会遇到以下问题:
(1)[EFX-0652 ERROR] 'EFX_MULT' instance 'mult' port 'CEA' is not permanently disabled in the Register Bypass mode.
说明:如果输入寄存器A_REG没有使能,CEA接口要设置为0
(2)[EFX-0652 ERROR] 'EFX_MULT' instance 'mult' port 'RSTA' is not permanently disabled in the Register Bypass mode.
说明:如果输入寄存器A_REG没有使能,RSTA接口要设置为0
(3)[EFX-0652 ERROR] 'EFX_MULT' instance 'mult' port 'CLK' is not permanently disabled in the Register Bypass mode.
说明:如果输入和输出寄存都没有使用的话,时钟也要设置为0。
所以这里提供下面的写法供参考。
EFX_MULT.WIDTH(18),.A_REG(AREG),.B_REG(BREG),.O_REG(OREG),.CLK_POLARITY(1'b1), // 0 falling edge, 1 rising edge.CEA_POLARITY(1'b1), // 0 falling edge, 1 rising edge.RSTA_POLARITY(1'b0), // 0 falling edge, 1 rising edge.RSTA_SYNC(1'b0), // 0 aynchronous, 1 synchronous.RSTA_VALUE(1'b0), // 0 reset, 1 set.CEB_POLARITY(1'b1), // 0 falling edge, 1 rising edge.RSTB_POLARITY(1'b0), // 0 falling edge, 1 rising edge.RSTB_SYNC(1'b0), // 0 aynchronous, 1 synchronous.RSTB_VALUE(1'b0), // 0 reset, 1 set.CEO_POLARITY(1'b1), // 0 falling edge, 1 rising edge.RSTO_POLARITY(1'b0), // 0 falling edge, 1 rising edge.RSTO_SYNC(1'b0), // 0 aynchronous, 1 synchronous.RSTO_VALUE(1'b0) // 0 reset, 1 set) mult (.CLK((AREG || BREG || OREG) ? clk : 0),.CEA(AREG),.RSTA(AREG ? rst : 1),.CEB(BREG),.RSTB(BREG ? rst : 1),.CEO(OREG),.RSTO(OREG ? rst : 1),.A(A_in),.B(B_in),.O(O_out));
