编程实验
将接近检测传感器集成到系统后,一个经常遇到的问题是如何正确选择接近检测的门限,以便在用户通话期间打开或关闭屏幕。门限设置须确保出现错误判断的几率非常低,而且能够支持绝大多数使用者的情况。
门限滞回例程
#define MAX44000_ADDR 0x94 #define INT_STATUS_REG 0x00 #define OFF_THRESHOLD 4600 #define OFF_DELAY 1 #define ON_THRESHOLD 4000 #define ON_DELAY 3 uint8 screenStatus; // 0 means off, 1 means on /* i2cWriteBytes() Arguments: uint8 address - device address uint8 start_reg - register where the first byte is written uint8 *data - data to write uint8 nbytes - number of bytes to write Consecutively writes several bytes to some i2c device starting at some specified address -- implemented elsewhere */ void i2cWriteBytes(uint8 address,uint8 start_reg,uint8 *data,uint8 nbytes); /* MAX44000InterruptHandler()
以下代码用于实现MAX44000 INT引脚的中断处理,假设MAX44000的接近检测传感器设置为14位模式,并已使能中断。此外,假设屏幕状态初始化为1或0,详细信息请参阅数据资料的寄存器说明部分。
void MAX44000InterruptHandler() {
uint8 i2cData[3];
i2cRead1Byte(MAX44000_ADDR,INT_STATUS_REG,&i2cData);
if (i2cData&0x01 != 0)
return; // check to make sure interrupt really fired
// this simultaneously clears the interrupt flag
if (screenStatus) {
i2cData[0] = ON_DELAY;
i2cData[1] = ON_THRESHOLD >> 8 & 0xBF; // set ABOVE = 0
i2cData[2] = ON_THRESHOLD & 0xFF;
} else {
i2cData[0] = OFF_DELAY;
i2cData[1] = OFF_THRESHOLD >> 8 | 0x40; // set ABOVE = 1
i2cData[2] = OFF_THRESHOLD & 0xFF;
} // set the new threshold depending on what the screen status was
// set the delay and threshold after each interrupt
i2cWriteBytes(MAX44000_ADDR,0x0A,i2cData,3);
return;
} // MAX44000InterruptHandler
