LT1994.pdf
消耗积分:5 | 格式:rar | 大小:333 | 2008-04-10
小组店小二
分享资料个
The LTC®6401-20 is a high-speed differential amplifi  er
targeted at processing signals from DC to 140MHz. The
part has been specifi  cally designed to drive 12-, 14- and
16-bit ADCs with low noise and low distortion, but can also
be used as a general-purpose broadband gain block.
The LTC6401-20 is easy to use, with minimal support
circuitry required. The output common mode voltage is
set using an external pin, independent of the inputs, which
eliminates the need for transformers or AC-coupling ca-
pacitors in many applications. The gain is internally fi xed
at 20dB (10V/V).
The LTC6401-20 saves space and power compared to
alternative solutions using IF gain blocks and transform-
ers. The LTC6401-20 is packaged in a compact 16-lead
3mm × 3mm QFN package and operates over the –40°C
to 85°C temperature range.
评论(0)
发评论
下载排行榜
