The EL2082 current-mode variable gain control IC can be connected in a way to minimize circuit noise. In the usual forward configuration, the circuit has an 80 nV/0Hz input noise which is constant with respect to gain adjustment. The circuit to be shown has an effective input noise which reduces as adjusted gain is increased. The circuit is useful in AGC or leveling functions where a relatively constant output amplitude is required for a range of inputs.
