Figure 1 shows how a three phase sine wave oscillator can be built using one UAF42 state variable filter along with some resistors and diodes. Three output nodes are available; highpass out, bandpass out and lowpass out. The signal at the bandpass and lowpass out nodes are 90° and 180° out of phase, respectively, with the highpass out node. An on-chip auxiliary op amp is available for use as a buffer or gain stage.
