鸿蒙Ability Kit(程序框架服务)【Ability与ServiceExtensionAbility通信】
介绍
本示例展示通过[IDL的方式]和 [@ohos.rpc] 等接口实现了Ability与ServiceExtensionAbility之间的通信。
效果预览
框架
使用说明
1.启动应用后,首页展示城市的天气信息,当前温度每隔5S会刷新一次。
工程目录
entry/src/main/ets/
|---Application
|---feature
|   |---HomeFeature.ets                  // 任务信息组件
|---MainAbility
|---Mock
|   |---RequestData.ts                   // 远程请求的数据
|   |---WeatherData.ts                   // 天气页面数据
|---model
|   |---FormDate.ts                      // 日期函数方法
|   |---Main.ts                          // 数据类
|---pages
|   |---home
|   |   |---BasicDataSource.ets          // 懒加载封装类
|   |   |---HomeContent.ets              // 内容组件
|   |   |---HoursWeather.ets             // 天气组件(小时)
|   |   |---IndexHeader.ets              // 首页头部组件
|   |   |---MultiDayWeather.ets          // 天气组件(天)
|   |---Home.ets                         // 首页
|---util
|   |---Logger.ts                        // 日志工具
|   |---Style.ts                         // 静态样式变量
具体实现
  • Ability与ServiceExtensionAbility通信的方法主要封装在idl_weather_service_proxy、idl_weather_service_stub、HomeFeature、ServiceExtAbility中。
  • 源码参考:[idl_weather_service_proxy.ts]
 * Copyright (c) 2022 Huawei Device Co., Ltd.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
import rpc from '@ohos.rpc'
import { updateWeatherCallback } from './i_idl_weather_service'
import IIdlWeatherService from './i_idl_weather_service'
import Logger from '../../../util/Logger'
export default class IdlWeatherServiceProxy implements IIdlWeatherService {
  constructor(proxy) {
    this.proxy = proxy
  updateWeather(data: number, callback: updateWeatherCallback): void {
    let _option = new rpc.MessageOption(0)
    let _data = new rpc.MessageParcel()
    let _reply = new rpc.MessageParcel()
    _data.writeInt(data)
    this.proxy.sendRequest(IdlWeatherServiceProxy.COMMAND_UPDATE_WEATHER, _data, _reply, _option).then(function (result) {
      if (result.errCode === 0) {
        let _errCode = result.reply.readInt()
        if (_errCode != 0) {
          let _returnValue = undefined
          callback(_errCode, _returnValue)
          return
        let _returnValue = result.reply.readInt()
      } else {
        Logger.error("sendRequest failed, errCode: " + result.errCode)
  static readonly COMMAND_UPDATE_WEATHER = 1
  private proxy
  • [idl_weather_service_stub.ts]
export default class IdlWeatherServiceStub extends rpc.RemoteObject implements IIdlWeatherService {
  constructor(des: string) {
    super(des)
  onRemoteRequest(code: number, data, reply, option): boolean {
    Logger.info("onRemoteRequest called, code = " + code)
    switch (code) {
      case IdlWeatherServiceStub.COMMAND_UPDATE_WEATHER: {
        let _data = data.readInt()
        this.updateWeather(_data, (errCode, returnValue) = > {
          reply.writeInt(errCode)
          if (errCode == 0) {
            reply.writeInt(returnValue)
        return true
      default: {
        Logger.error("invalid request code" + code)
        break
    return false
  • [HomeFeature]
import Logger from '../util/Logger'
import IdlWeatherServiceProxy from '../MainAbility/data/IIdlWeatherServiceTS/idl_weather_service_proxy'
const BUNDLE_NAME = "com.example.abilityconnectserviceextension"
const SERVICE_EXTENSION_ABILITY_NAME = "ServiceExtAbility"
const ERROR_CODE = -1 // 失败
const SUCCESS_CODE = 0 // 成功
export default class HomeFeature {
  connection = -1 // 初始值
  remoteCallback = null
  context = null
  options = null
  constructor(context) {
    this.context = context
    this.options = {
      outObj: this,
      // 连接成功时回调
      onConnect: function (elementName, proxy) {
        Logger.info(`onConnect success`)
        // 接收来自服务返回的实例
        let weatherProxy = new IdlWeatherServiceProxy(proxy)
        weatherProxy.updateWeather(123, this.outObj.remoteCallback)
      onDisconnect: function () {
        Logger.info(`onDisconnect`)
      onFailed: function () {
        Logger.info(`onFailed`)
  connectServiceExtAbility(callback) {
    Logger.info(`connectServiceExtAbility`)
    this.remoteCallback = callback
    let want = {
      bundleName: BUNDLE_NAME,
      abilityName: SERVICE_EXTENSION_ABILITY_NAME
    this.connection = this.context.connectAbility(want, this.options)
    Logger.info(`connectServiceExtAbility result:${this.connection}`)
  disconnectServiceExtAbility(callback) {
    Logger.info(`disconnectServiceExtAbility`)
    this.context.disconnectAbility(this.connection).then((data) = > {
      Logger.info(`disconnectAbility success:${JSON.stringify(data)}`)
      callback(SUCCESS_CODE)
    }).catch((error) = > {
      Logger.error(`disconnectAbility failed:${JSON.stringify(error)}`)
      callback(ERROR_CODE)
  • [ServiceExtAbility]
    框架
/*`HarmonyOS与OpenHarmony鸿蒙文档籽料:mau123789是v直接拿`
import ServiceExtension from '@ohos.app.ability.ServiceExtensionAbility'
import IdlWeatherServiceStub from '../MainAbility/data/IIdlWeatherServiceTS/idl_weather_service_stub'
import { updateWeatherCallback } from "../MainAbility/data/IIdlWeatherServiceTS/i_idl_weather_service"
import { getUpdateTemperature } from '../mock/RequestData'
class WeatherServiceStub extends IdlWeatherServiceStub {
  constructor(des) {
    super(des)
    let temperature = getUpdateTemperature()
    callback(0, temperature)
    Logger.info(`testIntTransaction: temperature: ${temperature}`)
export default class ServiceExtAbility extends ServiceExtension {
  onCreate(want) {
    Logger.info(`onCreate, want: ${want.abilityName}`)
  onRequest(want, startId) {
    Logger.info(`onRequest, want: ${want.abilityName}`)
  onConnect(want) {
    Logger.info(`onConnect , want: ${want.abilityName}`)
    return new WeatherServiceStub("weather service stub")
  onDisconnect(want) {
    Logger.info(`onDisconnect, want: ${want.abilityName}`)
  onDestroy() {
    Logger.info(`onDestroy`)
  • 建立服务器连接:通过HomeFeature中的this.context.connectAbility(want, this.options)方法来建立服务器连接;
  • 接收服务端实例并发送请求:连接成功时new IdlWeatherServiceProxy(proxy)来接收服务端实例,通过[@ohos.rpc] 接口来执行new rpc.MessageOption(0)、 new rpc.MessageParcel()、 new rpc.MessageParcel()获取 MessageParcel对象和请求的模式,调用idl_weather_service_proxy中的this.proxy.sendRequest()来发送请求;
  • 接收远程请求处理数据:在idl_weather_service_stub中接收远程请求并通过ServiceExtAbility中的updateWeather()函数来处理数据进行返回;
  • 获取数据:最后将获得的数据渲染到页面中去;
  • 断开连接:可以通过HomeFeature中的this.context.disconnectAbility(this.connection)方法来断开服务器连接,这里的this.connection是建立连接之后的返回值。
