xapp266代码,xapp266源代码
src/
addr_cntrl.v - Address Controller
clk_dcm.v - Clock DCM logic
controller.v - Main FCRAM controller logic
data_path.v - Data path
data_strobe.v - Data strobe generation
define.v - System parameters
fcram_cntrl.v - FCRAM top level
refresh_cntrl.v - Refresh controller
top.v - Instantiates FCRAM top level and user interface
user_application/
user_int_func.v - Passes all signals from the user interface directly
through to the FCRAM controller. This file may be used
for functional simulation. This file is not optimzied
for synthesis, since all the FCRAM top level outputs
are driven directly to I/O pads.
user_int_impl.v - User interface used for sample timing numbers. It
registers some I/O from the FCRAM top level in order
to emulate a true user interface. This file will affect
functional simulation (the added registers will
affect latencies).
sim/
testbench.v - Sample testbench which performs simple write and
read commands
NOTE: Requires FCRAM simulation models. These may be
attained from FCRAM vendor.
xilinx/
implement.bat - PC implementation script
implement.sh - UNIX implementation script
top.ucf - Constraints file
sythesis/
fcram.prj - Sample Synplify project
* FAQ
Q1) Where can I get FCRAM simulation models?
A1) Xilinx does not provide FCRAM simulation models. These models are
available from your FCRAM device vendor.
Q2) Do any pinout requirements exist?
A2) Yes. The Application Note "Pinout Constraints for Local Clock
Distribution" contains information on correctly choosing pins for
the data (DQ) and data strobe (DQS).
Additionally, the constraints file (top.ucf) contains sample pinouts
for a x16 device. Additionally, at the end of the file there are
additional sample pins that could be used to implement a x72 bit
interface.
Q3) What if I need to change the data widths or need to connect to
additional devices?
A3) The Verilog code is parametizable and can be easily modified to fit
different memory requirements. See Appendix A for further details.
As mentioned in that section, if the controller will interface to
multiple devices, it may be required (based on a loading analysis
and other signal integrity factors) to duplicate some drivers.
FCRAM vendors can provide suggested board layout information.
Q4) During my simulation, I specify a row and address to be accessed.
However, when I look at the address output on ddr_ad, it does not
seem to match what I expected?
A4) This has to do with the data mask function. As described in the
Application Note, the data mask is provided to the FCRAM device
during every LAL stage. If all transfers are to be accepted, then
the data mask is set to "Write All Words".
- If BL=2, then the data mask is set to all 0's.
- If BL=4, then the data mask for "Write All Words" is "1010". This is
provided during the LAL command on the ddr_ad pins 14-11. Therefore,
if a row of "0000h" was provided, it would show up as "5000h".
Q5) Why is there an AREA GROUP constraint in the UCF? Do I need this?
A5) There is a known problem with PAR in placing dual-port LUT rams. The
problem in this case can cause the "TS_DQS_2_RCLK" FROM-TO constraint
to fail. By placing an area group on the dual-port lut ram (which
is contained in the "synch_dqs2clk" module), it simply aids PAR in
choosing a location. If timing constraints are met without this
constraint, then it is not required.
Additionally, if a user changes pinouts, the area group should be
moved with the new location.
Q6) Can I place my DQ and DQS pins on the top or bottom of the device?
A6) Using the clocking scheme described in the Application Note, no.
In order to use the local clock routes, the clock input pad (DQS) and
the data loads (DQ) must be placed on the left or right edges of the
device. If placement on the top or bottom is required, then another
clocking scheme (such as capturing DQ with a phase shifted clock) would
have to be used, and the code modified accordingly.
Q7) PAR and Timing Analysis state that there are timing errors, even though
all constraints were met! What is happening?
A7) The paths that are getting flagged as errors are hold violations which
are invalid paths (they are Timing Ignored (TIG) in the constraints
file). Look at the timing report for further details. This will be
corrected in a future version of the Xilinx tools.
