xapp353代码
消耗积分:3 | 格式:rar | 大小:233 | 2009-06-14
31274
分享资料个
xapp353代码
THIS DESIGN IS PROVIDED TO YOU 揂S IS? XILINX MAKES AND YOU RECEIVE NO WARRANTIES OR
CONDITIONS, EXPRESS, IMPLIED,  STATUTORY OR OTHERWISE, AND XILINX SPECIFICALLY DISCLAIMS ANY
IMPLIED WARRANTIES OF MERCHANTABILITY, NON-INFRINGEMENT, OR FITNESS FOR A PARTICULAR
PURPOSE. This design has not been verified on hardware (as opposed to simulations), and it should be used only as an
example design, not as a fully functional core. XILINX does not warrant the performance, functionality, or operation of this
Design will meet your requirements, or that the operation of the Design will be uninterrupted or error free, or that defects in
the Design will be corrected. Furthermore, XILINX does not warrant or make any representations regarding use or the
results of the use of the Design in terms of correctness, accuracy, reliability or otherwise.
评论(0)
发评论
下载排行榜
