PT32L007F8P7K& QMA6100P IIC 通讯源代码分享
  * @file    qma6100p.c
  * @author  Yangzhiqiang@qst
  * @version V1.0
  * @date    2020-5-27
  * @brief    qma6100p
  * @attention
#include "qma6100p.h"
#include "PT32x007x.h"
#include "string.h"
#define MT6701_ADDR               (0x0C)
#define fabs(x)                    (x < 0 ? -x : x)
void delay_us(uint32_t delay)
    uint32_t i,j,k;
    for(i=0;i    {
        for(j=0;j<100;j++)
            k++;
void Acce_Write_Byte(unsigned int WriteAddr, u8 data)
//    int i;
/******************等待从机ready***************/
    I2C_GenerateEvent(I2C,I2C_Event_Start,DISABLE);
    I2C->CCR |= I2C_CCR_SI | I2C_CCR_ACK;
    I2C_Cmd(I2C,DISABLE);
    I2C_Cmd(I2C,ENABLE);
    I2C_GenerateEvent(I2C,I2C_Event_Start,ENABLE);
    while(I2C_GetFlagStatus(I2C,I2C_FLAG_StartOk)!= SET);
//    printf("---%s  %d---n", __func__, __LINE__) ;
    I2C_SendAddr(I2C, MT6701_ADDR);//器件地址,写
    while(I2C_GetFlagStatus(I2C,I2C_FLAG_MASGetAckW)!=SET);
    printf("%s %drn", __func__, __LINE__) ;
    I2C_SendData(I2C,WriteAddr);//发送要写的字地址
    while(I2C_GetFlagStatus(I2C,I2C_FLAG_MDSGetAck)!=SET);
    I2C_SendData(I2C, data);
    while(I2C_GetFlagStatus(I2C,I2C_FLAG_MDSGetAck) != SET);
        /******************发送停止位***************/
    I2C_GenerateEvent(I2C,I2C_Event_Stop,ENABLE);
//uint8_t I2C_EE_Read(u8* pBuffer,u16 ReadAddr, u16 DeviceAddr, u16 data_size)
uint8_t Acce_Read_Byte(u16 ReadAddr)
//    int i;
    uint8_t date = 0 ;
//printf("---%s  %d---n", __func__, __LINE__) ;
    I2C_SendData(I2C,ReadAddr);//发送要读的页地址
/******************接收数据***************/
    I2C_SendAddr(I2C, MT6701_ADDR|0x01);//器件地址,读
    while(I2C_GetFlagStatus(I2C,I2C_FLAG_MASGetAckR)!=SET);
    I2C->CCR=I2C_CCR_ACK|I2C_CCR_SI;//主机发送NACK
    while(I2C_GetFlagStatus(I2C,I2C_FLAG_MDGSendNack) != SET);
    date = I2C_ReceiveData(I2C);
    return date ;
uint8_t MT6813_read_reg(uint8_t Reg)
    u8 RegVal = 0;
    RegVal = Acce_Read_Byte(Reg);
    return RegVal;
void MT6813_write_reg(uint8_t Reg,uint8_t Val)
    Acce_Write_Byte(Reg, Val);
void MT6701_INIT(void)
    uint8_t Buff[2];
//    Buff[0] = MT6813_read_reg(0x22);
//    if(Buff[0] == 0x60)
//        printf("RG 0x22=%xrn",Buff[0]);
//        return;
    MT6813_write_reg(0x22, 0x60);  //
    delay_us(10) ;
    MT6813_write_reg(0x24, 0x80);  //
    delay_us(10) ;
    MT6813_write_reg(0x27, 0xB8);
    delay_us(10) ;
    printf("RG 0x22 C=%xrn",Buff[0]);
    Buff[0] = MT6813_read_reg(0x24);
    printf("RG 0x24 D=%xrn",Buff[0]);
    //save eeprom
    MT6813_write_reg(0x09, 0xB3);
    MT6813_write_reg(0x0A, 0x05);
short angle_now;
uint8_t MT6701_GetData(uint8_t *Magnet)
    uint8_t Buff[6];
    int data;
    float angle;
    Buff[0] = MT6813_read_reg(0x03);
    Buff[1] = MT6813_read_reg(0x04);
    Magnet[0] = Buff[0];
    Magnet[1] = Buff[1];
    data = (short)((Magnet[0]<<8)|(Magnet[1]));
    data = data>>2;
    angle = (float)(data*0.022);
    if(angle<0)
        angle = 360+angle;
    // if((short)angle != angle_now)
    //     angle_now = (short)angle;
    //     printf("angle=%drn",angle_now);
    printf("angle=%.2frn",angle);
    return angle_now;
uint8_t Zero_point_programming(void)
    uint8_t Buff[2],ZH,ZL;
    int data ;
    Buff[0] = MT6813_read_reg(0x32);
    ZH = Buff[0] & 0xf0;
    MT6813_write_reg(0x32, ZH);
    MT6813_write_reg(0x33, 0x00);
    data = (short)((Buff[0]<<8)|(Buff[1]));
    data = data>>2;  //14bit
    data = data>>2;  //12bit
    ZH = ZH | (uint8_t)(data >> 8) ;
    ZL = (uint8_t)(data & 0x0f) ;
    MT6813_write_reg(0x33, ZL);
    //save eeprom
    if((Buff[0] == ZH) && (Buff[1] == ZL))
        return 1;
    return 0;
mcu
PT32L007是一款Cortex M0 内核的MCU,该系列产品最高主频可达64MHz,1.8~5.5v,-40~105℃,Flash 64Kbyte,SRAM 16Kbyte,深度睡眠电流低至 500nA,支持16位低功耗定时器,12bit ADC,UART x 2,I2C,SPI,Timer x 6,18 GPIO,封装TSSOP20/QFN20,广泛应用于消费电子、手持设备、消防安防、仪器仪表、物联网、工业控制等领域。
