本文主要阐述了用VC++设计数字微波监控系统中故障管理模块的开发过程。故障 管理模块的主要功能是分析所接收的数据,自动记录告警发生的时间、位置和级别,并在系统恢复正常后自动记录系统恢复时间。 关键词: 故障管理 告警监测 故障定位 告警查询 Abstract:This article tells the development of exception handling module of the Digital Microwave Monitor And Control System based on Visual C++. Exception handling module’s main function is to analyze received data, to record the time, place and level of giving a alarm andto note the time of system renewing automatically after the system works normally. . Keyword: exception handle alarm monitor faults position alarm inquire
