0.1-10Hz放大器噪声测量滤波器电路图
滤波器电路
96人已加入
  This circuit is designed to amplify low frequency noise (0.1Hz to 10Hz) to a level that is easily measured by and oscilloscope. It achieves this function with a 0.1Hz second order high pass filter and a to 10Hz forth order low pass filter. The 0.1Hz to 10Hz noise measurement is a common figure of merit given in amplifier data sheets. This design is intended to facilitate the measurement 0.1Hz to 10Hz noise for the commonly used different package styles.
滤波器
