MAX44285
集成电路
75人已加入
MAX44285概述
The MAX44285 dual-channel high-side current-sense amplifier has precision accuracy specifications of VOS less than 10µV (max) and gain error less than 0.1% (max).
The MAX44285 features an input common-mode voltage range from 2.7V to 36V with 80kHz of small-signal bandwidth, which makes it ideal for interfacing with a SAR ADC for multichannel multiplexed data acquisition systems.
The MAX44285 operates over the -40°C to +125°C temperature range. The MAX44285 is offered in 8-bump WLP and 8-pin µMAX® packages.
MAX44285关键特性
2.7V to 36V Input Common Mode
Low 10µV (max) Input Offset Voltage
Low 0.1% (max) Gain Error
Gain Options
G = 12.5V/V (MAX44285L)
G = 20V/V (MAX44285T)
G = 50V/V (MAX44285F)
G = 100V/V (MAX44285H)
1mm x 2mm 8-Bump WLP and 8-Pin µMAX Packages
MAX44285应用/使用
Base Stations and Communication Equipment
工业控制与自动化
电源管理系统
服务器背板
