鸿蒙开发组件:创建DataAbility
创建DataAbility
实现DataAbility中Insert、Query、Update、Delete接口的业务内容。保证能够满足数据库存储业务的基本需求。BatchInsert与ExecuteBatch接口已经在系统中实现遍历逻辑,依赖Insert、Query、Update、Delete接口逻辑,来实现数据的批量处理。 开发前请熟悉鸿蒙开发指导文档 :[gitee.com/li-shizhen-skin/harmony-os/blob/master/README.md]
组件
创建DataAbility的代码示例如下:
import featureAbility from '@ohos.ability.featureAbility';
import type common from '@ohos.app.ability.common';
import type Want from '@ohos.app.ability.Want';
import type { AsyncCallback, BusinessError } from '@ohos.base';
import dataAbility from '@ohos.data.dataAbility';
import rdb from '@ohos.data.rdb';
import hilog from '@ohos.hilog';
let TABLE_NAME = 'book';
let STORE_CONFIG: rdb.StoreConfig = { name: 'book.db' };
let SQL_CREATE_TABLE = 'CREATE TABLE IF NOT EXISTS book(id INTEGER PRIMARY KEY AUTOINCREMENT, name TEXT NOT NULL, introduction TEXT NOT NULL)';
let rdbStore: rdb.RdbStore | undefined = undefined;
const TAG: string = '[Sample_FAModelAbilityDevelop]';
const domain: number = 0xFF00;
class DataAbility {
  onInitialized(want: Want): void {
    hilog.info(domain, TAG, 'DataAbility onInitialized, abilityInfo:' + want.bundleName);
    let context: common.BaseContext = { stageMode: featureAbility.getContext().stageMode };
    rdb.getRdbStore(context, STORE_CONFIG, 1, (err, store) = > {
      hilog.info(domain, TAG, 'DataAbility getRdbStore callback');
      store.executeSql(SQL_CREATE_TABLE, []);
      rdbStore = store;
  insert(uri: string, valueBucket: rdb.ValuesBucket, callback: AsyncCallback< number >): void {
    hilog.info(domain, TAG, 'DataAbility insert start');
    if (rdbStore) {
      rdbStore.insert(TABLE_NAME, valueBucket, callback);
  batchInsert(uri: string, valueBuckets: Array< rdb.ValuesBucket >, callback: AsyncCallback< number >): void {
    hilog.info(domain, TAG, 'DataAbility batch insert start');
    if (rdbStore) {
      for (let i = 0; i < valueBuckets.length; i++) {
        hilog.info(domain, TAG, 'DataAbility batch insert i=' + i);
        if (i < valueBuckets.length - 1) {
          rdbStore.insert(TABLE_NAME, valueBuckets[i], (err: BusinessError, num: number) = > {
            hilog.info(domain, TAG, 'DataAbility batch insert ret=' + num);
        } else {
          rdbStore.insert(TABLE_NAME, valueBuckets[i], callback);
  query(uri: string, columns: Array< string >, predicates: dataAbility.DataAbilityPredicates, callback: AsyncCallback< rdb.ResultSet >): void {
    hilog.info(domain, TAG, 'DataAbility query start');
    let rdbPredicates = dataAbility.createRdbPredicates(TABLE_NAME, predicates);
    if (rdbStore) {
      rdbStore.query(rdbPredicates, columns, callback);
  update(uri: string, valueBucket: rdb.ValuesBucket, predicates: dataAbility.DataAbilityPredicates, callback: AsyncCallback< number >): void {
    hilog.info(domain, TAG, 'DataAbility update start');
    if (rdbStore) {
      rdbStore.update(valueBucket, rdbPredicates, callback);
  delete(uri: string, predicates: dataAbility.DataAbilityPredicates, callback: AsyncCallback< number >): void {
    hilog.info(domain, TAG, 'DataAbility delete start');
    if (rdbStore) {
      rdbStore.delete(rdbPredicates, callback);
export default new DataAbility();
