介绍一种新型螺线管磁场测量仪,利用集成霍耳传感器测磁场,消除了热磁效应的影响,仪器结构合理、外型美观、集成化程度高、操作方便、测量结果精确度高。 关键词:螺线管;磁场;集成霍耳传感器;热磁效应;霍耳效应;磁感应强度;灵敏度 Abstract :This article introduce a new type of solenoid magnetic field measuring apparatus. It ap2 plies integrated Hall sensor to measuring magnetic field intensity and diminishing impact of heat magnetic effect . This apparatus has a reasonable structure , a beautiful look , and a high - level integration. It can be operated freely ,conveniently ,and the result of survey is very precise. Key words :solenoid ; magnetic field ; integrated Hall sensor ; heat magnetic effect ; Hall effect ; magnetic field intensity ;sensitivity
