鸿蒙开发组件:启动与访问DataAbility
启动DataAbility
启动DataAbility会获取一个工具接口类对象(DataAbilityHelper)。启动DataAbility的示例代码如下:
import featureAbility from '@ohos.ability.featureAbility';
import ability from '@ohos.ability.ability';
let uri: string = 'dataability:///com.samples.famodelabilitydevelop.DataAbility';
let DAHelper: ability.DataAbilityHelper = featureAbility.acquireDataAbilityHelper(uri);
访问DataAbility
访问DataAbility需导入基础依赖包,以及获取与DataAbility子模块通信的URI字符串。
其中,基础依赖包包括: 开发前请熟悉鸿蒙开发指导文档 :[gitee.com/li-shizhen-skin/harmony-os/blob/master/README.md]
组件
  • @ohos.ability.featureAbility
  • @ohos.data.dataAbility
访问DataAbility的示例代码如下:
  1. 创建工具接口类对象。
    import ohos_data_ability from '@ohos.data.dataAbility';
    // 作为参数传递的URI,与config中定义的URI的区别是多了一个"/",有三个"/"
  2. 构建数据库相关的RDB数据。
    import rdb from '@ohos.data.rdb';
    let valuesBucket_insert: rdb.ValuesBucket = { name: 'Rose', introduction: 'insert' };
    let valuesBucket_update: rdb.ValuesBucket = { name: 'Rose', introduction: 'update' };
    let crowd = new Array({ name: 'Rose', introduction: 'batchInsert_one' } as rdb.ValuesBucket,
      { name: 'Rose', introduction: 'batchInsert_two' } as rdb.ValuesBucket);
    let columnArray = new Array('id', 'name', 'introduction');
    let predicates = new ohos_data_ability.DataAbilityPredicates();
    注:关于DataAbilityPredicates的详细内容,请参考[DataAbility谓词]。
  3. 调用insert方法向指定的DataAbility子模块插入数据。
    import { BusinessError } from '@ohos.base';
    import promptAction from '@ohos.promptAction';
    import hilog from '@ohos.hilog';
    const TAG: string = 'PageDataAbility';
    // callback方式调用:
    const domain: number = 0xFF00;
    @Entry
    @Component
    struct PageDataAbility {
      private valuesBucket_insert: rdb.ValuesBucket = { name: 'Rose', introduction: 'insert' };
      private uri = 'dataability:///com.samples.famodelabilitydevelop.DataAbility';
      private DAHelper = featureAbility.acquireDataAbilityHelper(this.uri);
      build() {
        Column() {
          List({ initialIndex: 0 }) {
            ListItemGroup() {
              ListItem() {
                Flex({ justifyContent: FlexAlign.SpaceBetween, alignContent: FlexAlign.Center }) {
                .onClick(() = > {
                  // callback方式调用:
                  this.DAHelper.insert(this.uri, this.valuesBucket_insert, (error: BusinessError, data: number) = > {
                    if (error && error.code !== 0) {
                      promptAction.showToast({
                        message: $r('app.string.insert_failed_toast')
                    } else {
                        message: $r('app.string.insert_success_toast')
                    hilog.info(domain, TAG, 'DAHelper insert result: ' + data + ', error: ' + JSON.stringify(error));
    @Entry
    @Component
      build() {
        Column() {
            ListItemGroup() {
              ListItem() {
                .onClick(() = > {
                  // promise方式调用(await需要在async方法中使用):
                  this.DAHelper.insert(this.uri, this.valuesBucket_insert).then((datainsert) = > {
                    hilog.info(domain, TAG, 'DAHelper insert result: ' + datainsert);
                  }).catch((error: BusinessError) = > {
                    hilog.error(domain, TAG, `DAHelper insert failed. Cause: ${error.message}`);
  4. 调用delete方法删除DataAbility子模块中指定的数据。
    @Entry
    @Component
      private predicates = new ohos_data_ability.DataAbilityPredicates();
      build() {
        Column() {
            ListItemGroup() {
              ListItem() {
                .onClick(() = > {
                  // callback方式调用:
                  this.DAHelper.delete(this.uri, this.predicates, (error, data) = > {
                        message: $r('app.string.delete_failed_toast')
                    } else {
                        message: $r('app.string.delete_success_toast')
                    hilog.info(domain, TAG, 'DAHelper delete result: ' + data + ', error: ' + JSON.stringify(error));
    @Entry
    @Component
      build() {
        Column() {
            ListItemGroup() {
              ListItem() {
                .onClick(() = > {
                  this.DAHelper.delete(this.uri, this.predicates).then((datadelete) = > {
                    hilog.info(domain, TAG, 'DAHelper delete result: ' + datadelete);
                    hilog.error(domain, TAG, `DAHelper delete failed. Cause: ${error.message}`);
  5. 调用update方法更新指定DataAbility子模块中的数据。
    @Entry
    @Component
      private valuesBucket_update: rdb.ValuesBucket = { name: 'Rose', introduction: 'update' };
      build() {
        Column() {
            ListItemGroup() {
              ListItem() {
                .onClick(() = > {
                  // callback方式调用:
                  this.predicates.equalTo('name', 'Rose');
                  this.DAHelper.update(this.uri, this.valuesBucket_update, this.predicates, (error, data) = > {
                        message: $r('app.string.update_failed_toast')
                    } else {
                        message: $r('app.string.update_success_toast')
                    hilog.info(domain, TAG, 'DAHelper update result: ' + data + ', error: ' + JSON.stringify(error));
    @Entry
    @Component
      build() {
        Column() {
            ListItemGroup() {
              ListItem() {
                .onClick(() = > {
                  this.DAHelper.update(this.uri, this.valuesBucket_update, this.predicates).then((dataupdate) = > {
                    hilog.info(domain, TAG, 'DAHelper update result: ' + dataupdate);
                    hilog.error(domain, TAG, `DAHelper update failed. Cause: ${error.message}`);
  6. 调用query方法在指定的DataAbility子模块中查找数据。
    @Entry
    @Component
      private columnArray = new Array('id', 'name', 'introduction');
      build() {
        Column() {
            ListItemGroup() {
              ListItem() {
                .onClick(() = > {
                  // callback方式调用:
                  this.DAHelper.query(this.uri, this.columnArray, this.predicates, (error, data) = > {
                        message: $r('app.string.query_failed_toast')
                      hilog.error(domain, TAG, `DAHelper query failed. Cause: ${error.message}`);
                    } else {
                        message: $r('app.string.query_success_toast')
                    // ResultSet是一个数据集合的游标,默认指向第-1个记录,有效的数据从0开始。
                    while (data.goToNextRow()) {
                      const id = data.getLong(data.getColumnIndex('id'));
                      const name = data.getString(data.getColumnIndex('name'));
                      const introduction = data.getString(data.getColumnIndex('introduction'));
                      hilog.info(domain, TAG, `DAHelper query result:id = [${id}], name = [${name}], introduction = [${introduction}]`);
                    // 释放数据集的内存
                    data.close();
    @Entry
    @Component
      build() {
        Column() {
            ListItemGroup() {
              ListItem() {
                .onClick(() = > {
                  this.DAHelper.query(this.uri, this.columnArray, this.predicates).then((dataquery) = > {
                    while (dataquery.goToNextRow()) {
                      const id = dataquery.getLong(dataquery.getColumnIndex('id'));
                      const name = dataquery.getString(dataquery.getColumnIndex('name'));
                      const introduction = dataquery.getString(dataquery.getColumnIndex('introduction'));
                    // 释放数据集的内存
                    dataquery.close();
  7. 调用batchInsert方法向指定的DataAbility子模块批量插入数据。
    @Entry
    @Component
      private crowd = new Array({ name: 'Rose', introduction: 'batchInsert_one' } as rdb.ValuesBucket,
      build() {
        Column() {
            ListItemGroup() {
              ListItem() {
                .onClick(() = > {
                  // callback方式调用:
                  this.DAHelper.batchInsert(this.uri, this.crowd, (error, data) = > {
                        message: $r('app.string.batchInsert_failed_toast')
                    } else {
                        message: $r('app.string.batchInsert_success_toast')
                    hilog.info(domain, TAG, 'DAHelper batchInsert result: ' + data + ', error: ' + JSON.stringify(error));
    @Entry
    @Component
      build() {
        Column() {
            ListItemGroup() {
              ListItem() {
                .onClick(() = > {
                  this.DAHelper.batchInsert(this.uri, this.crowd).then((databatchInsert) = > {
                    hilog.info(domain, TAG, 'DAHelper batchInsert result: ' + databatchInsert);
                    hilog.error(domain, TAG, `DAHelper batchInsert failed. Cause: ${error.message}`);
  8. 调用executeBatch方法向指定的DataAbility子模块进行数据的批量处理。
    @Entry
    @Component
      build() {
        Column() {
            ListItemGroup() {
              ListItem() {
                .onClick(() = > {
                  // callback方式调用:
                  let operations: Array< ability.DataAbilityOperation > = [{
                    uri: this.uri,
                    type: featureAbility.DataAbilityOperationType.TYPE_INSERT,
                    valuesBucket: { name: 'Rose', introduction: 'executeBatch' },
                    predicates: this.predicates,
                    expectedCount: 0,
                    predicatesBackReferences: undefined,
                    interrupted: true,
                  this.DAHelper.executeBatch(this.uri, operations, (error, data) = > {
                        message: $r('app.string.executeBatch_failed_toast')
                    } else {
                        message: $r('app.string.executeBatch_success_toast')
                    hilog.info(domain, TAG, `DAHelper executeBatch, result: ` + JSON.stringify(data) + ', error: ' + JSON.stringify(error));
    @Entry
    @Component
      build() {
        Column() {
            ListItemGroup() {
              ListItem() {
                .onClick(() = > {
                    uri: this.uri,
                    expectedCount: 0,
                    interrupted: true,
                  this.DAHelper.executeBatch(this.uri, operations).then((dataquery) = > {
                    hilog.info(domain, TAG, 'DAHelper executeBatch result: ' + JSON.stringify(dataquery));
                    hilog.error(domain, TAG, `DAHelper executeBatch failed. Cause: ${error.message}`);
