鸿蒙开发Ability Kit程序框架服务:Stage模型启动FA模型PageAbility
本小节介绍Stage模型的两种应用组件如何启动FA模型的PageAbility组件。
UIAbility启动PageAbility
UIAbility启动PageAbility和UIAbility启动UIAbility的方式完全相同。
说明: 需注意FA模型中abilityName由bundleName + AbilityName组成,具体见示例。 开发前请熟悉鸿蒙开发指导文档 :[gitee.com/li-shizhen-skin/harmony-os/blob/master/README.md]
import { common, Want } from '@kit.AbilityKit';
import { hilog } from '@kit.PerformanceAnalysisKit';
import { BusinessError } from '@kit.BasicServicesKit';
const TAG: string = '[Page_StartFAModel]';
const DOMAIN_NUMBER: number = 0xFF00;
@Entry
@Component
struct Page_StartFAModel {
  private context = getContext(this) as common.UIAbilityContext;
  build() {
    Column() {
      List({ initialIndex: 0 }) {
        ListItem() {
          Row() {
          .onClick(() = > {
            let want: Want = {
              bundleName: 'com.samples.famodelabilitydevelop',
              abilityName: 'com.samples.famodelabilitydevelop.MainAbility'
            this.context.startAbility(want).then(() = > {
              hilog.info(DOMAIN_NUMBER, TAG, 'Start Ability successfully.');
            }).catch((error: BusinessError) = > {
              hilog.error(DOMAIN_NUMBER, TAG, `Ability failed: ` + JSON.stringify(error));
UIAbility访问PageAbility(startAbilityForResult)
startAbilityForResult和startAbility的区别是当PageAbility销毁的时候会返回执行结果。
UIAbility通过startAbilityForResult启动PageABility和UIAbility通过startAbilityForResult启动UIAbility的代码一样,没有任何区别。
HarmonyOS与OpenHarmony鸿蒙文档籽料:mau123789是v直接拿
鸿蒙
import { promptAction } from '@kit.ArkUI';
@Entry
@Component
  build() {
    Column() {
        ListItem() {
          Row() {
          .onClick(() = > {
            let want: Want = {
              abilityName: 'com.samples.famodelabilitydevelop.MainAbility',
            this.context.startAbilityForResult(want).then((result) = > {
              hilog.info(DOMAIN_NUMBER, TAG, 'Ability verify result: ' + JSON.stringify(result));
              if (result !== null) {
                promptAction.showToast({
                  message: JSON.stringify(result)
ExtensionAbility启动PageAbility
下面以ServiceExtensionAbility为例来说明ExtensionAbility启动PageAbility。ServiceExtensionAbility启动PageAbility和ServiceExtensionAbility启动UIAbility的方式完全相同。
import { Want, ServiceExtensionAbility } from '@kit.AbilityKit';
import { rpc } from '@kit.IPCKit';
import ServiceExtImpl from '../IdlServiceExt/idl_service_ext_impl';
const TAG: string = '[ServiceExtAbility]';
export default class ServiceExtAbility extends ServiceExtensionAbility {
  serviceExtImpl: ServiceExtImpl = new ServiceExtImpl('ExtImpl');
  onCreate(want: Want): void {
    let serviceExtensionContext = this.context;
    hilog.info(DOMAIN_NUMBER, TAG, `onCreate, want: ${want.abilityName}`);
  onRequest(want: Want, startId: number): void {
    hilog.info(DOMAIN_NUMBER, TAG, `onRequest, want: ${want.abilityName}`);
    if (want.parameters?.key === 'ConnectFaPageAbility') {
      let wantFA: Want = {
      this.context.startAbility(wantFA).then(() = > {
        hilog.info(DOMAIN_NUMBER, TAG, `Ability failed: ${JSON.stringify(error)}`);
  onConnect(want: Want): rpc.RemoteObject {
    hilog.info(DOMAIN_NUMBER, TAG, `onConnect, want: ${want.abilityName}`);
    // 返回ServiceExtImpl对象,客户端获取后便可以与ServiceExtensionAbility进行通信
    return this.serviceExtImpl as rpc.RemoteObject;
  onDisconnect(want: Want): void {
    hilog.info(DOMAIN_NUMBER, TAG, `onDisconnect, want: ${want.abilityName}`);
  onDestroy(): void {
    hilog.info(DOMAIN_NUMBER, TAG, 'onDestroy');
