2.一般说明
LT8711UXE2是一款高性能的Type-C/DP1.4到HDMI2.0转换器,设计用于将USBType-C源或DP1.4源连接到HDMI2.0收发器。该LT8711UXE2集成了一个符合DP1.4标准的接收器和一个符合HDMI2.0标准的发射器。此外,还包括用于CC通信的两个CC控制器,以实现DP Alt模式和功率传递功能,一个用于上游Type-C端口,另一个用于下游端口。
DP接口包括4个主通道、辅助通道和HPD信号。接收器支持最大的还提供数字音频输出接口:12S和SPDIF。从DP数据流中提取并恢复音频流,然后路由到数字音频输出或HDMI输出。该设备支持8通道LPCM或压缩音频在最大192kHz采样率。该设备能够自动操作,该操作由集成微处理器启用,该微处理器使用嵌入式SPI闪存存储固件。系统控制也可通过使用专用配置12C从站接口。
3.应用程序
●对接站
加密狗
- General DescriptionThe LT8711UXE2 is a high performance Type-C/DP1.4 toHDMI2.0 converter, designed to connect a USB Type-Csource or a DP1.4 source to an HDMI2.0 sink. TheLT8711UXE2 integrates a DP1.4 compliant receiver, andan HDMI2.0 compliant transmitter. Also, two CCcontrollers are included for CC communication toimplement DP Alt Mode and power delivery function, onefor upstream Type-C port and another for downstreamport.The DP interface comprises 4 main lanes, tell 18171547226,AUX channel,and HPD signal. The receiver supports maximumalso provides digital audio output interfaces: I2S andSPDIF. The audio stream is extracted and recovered fromDP data stream, and then routed to digital audio outputsor HDMI output. The device supports 8-channel LPCM orcompressed audio at maximum 192kHz sample rate.The device is capable of automatic operation which isenabled by an integrated microprocessor that uses anembedded SPI flash for firmware storage. System controlis also available through the use of a dedicatedconfiguration I2C slave interface.
- Applications
Docking station
Dongle
*附件:Lontium-LT8711UXE2.pdf
