鸿蒙开发:Universal Keystore Kit 密钥管理服务 加解密ArkTS 电子说
以AES 128密钥为例,完成加解密。具体的场景介绍及支持的算法规格。
生成密钥
gitee.com/li-shizhen-skin/harmony-os/blob/master/README.md]除此之外,开发者也可以参考[密钥导入],导入已有的密钥。
加密
解密
删除密钥
当密钥废弃不用时,需要调用[deleteKeyItem]删除密钥,具体请参考[密钥删除]。
`HarmonyOS与OpenHarmony鸿蒙文档籽料:mau123789是v直接拿`
* 以下以AES 128密钥的Promise操作使用为例
import { huks } from "@kit.UniversalKeystoreKit";
let aesKeyAlias = 'test_aesKeyAlias';
let handle:number;
let plainText = '123456';
let IV = '001122334455';
let cipherData:Uint8Array;
function StringToUint8Array(str: String) {
let arr:number[]=new Array();
for (let i = 0, j = str.length; i < j; ++i) {
arr.push(str.charCodeAt(i));
return new Uint8Array(arr);
function Uint8ArrayToString(fileData:Uint8Array) {
let dataString = '';
for (let i = 0; i < fileData.length; i++) {
dataString += String.fromCharCode(fileData[i]);
return dataString;
function GetAesGenerateProperties() {
let properties: Array< huks.HuksParam > =[{
tag: huks.HuksTag.HUKS_TAG_ALGORITHM,
value: huks.HuksKeyAlg.HUKS_ALG_AES
tag: huks.HuksTag.HUKS_TAG_KEY_SIZE,
value: huks.HuksKeySize.HUKS_AES_KEY_SIZE_128
tag: huks.HuksTag.HUKS_TAG_PURPOSE,
value: huks.HuksKeyPurpose.HUKS_KEY_PURPOSE_ENCRYPT |
huks.HuksKeyPurpose.HUKS_KEY_PURPOSE_DECRYPT
return properties;
function GetAesEncryptProperties() {
let properties: Array< huks.HuksParam > = [{
tag: huks.HuksTag.HUKS_TAG_PADDING,
value: huks.HuksKeyPadding.HUKS_PADDING_PKCS7
tag: huks.HuksTag.HUKS_TAG_BLOCK_MODE,
value: huks.HuksCipherMode.HUKS_MODE_CBC
tag: huks.HuksTag.HUKS_TAG_IV,
value: StringToUint8Array(IV)
return properties;
function GetAesDecryptProperties() {
value: huks.HuksKeyPurpose.HUKS_KEY_PURPOSE_DECRYPT
return properties;
async function GenerateAesKey() {
* 模拟生成密钥场景
* 1. 确定密钥别名
* 2. 获取生成密钥算法参数配置
let genProperties = GetAesGenerateProperties();
let options: huks.HuksOptions = {
properties: genProperties
* 3. 调用generateKeyItem
await huks.generateKeyItem(aesKeyAlias, options)
.then((data) = > {
console.info(`promise: generate AES Key success, data = ${JSON.stringify(data)}`);
}).catch((error: Error)= >{
console.error(`promise: generate AES Key failed, ${JSON.stringify(error)}`);
async function EncryptData() {
* 模拟加密场景
* 1. 获取密钥别名
* 2. 获取待加密的数据
* 3. 获取加密算法参数配置
let encryptProperties = GetAesEncryptProperties();
properties: encryptProperties,
inData: StringToUint8Array(plainText)
* 4. 调用initSession获取handle
await huks.initSession(aesKeyAlias, options)
.then((data) = > {
handle = data.handle;
console.error(`promise: init EncryptData failed, ${JSON.stringify(error)}`);
* 5. 调用finishSession获取加密后的密文
await huks.finishSession(handle, options)
.then((data) = > {
console.info(`promise: encrypt data success, data is `+ Uint8ArrayToString(data.outData as Uint8Array));
cipherData = data.outData as Uint8Array;
console.error(`promise: encrypt data failed, ${JSON.stringify(error)}`);
async function DecryptData() {
* 模拟解密场景
* 1. 获取密钥别名
* 2. 获取待解密的密文
* 3. 获取解密算法参数配置
let decryptOptions = GetAesDecryptProperties()
properties: decryptOptions,
inData: cipherData
.then((data) = > {
console.error(`promise: init DecryptData failed, ${JSON.stringify(error)}`);
* 5. 调用finishSession获取解密后的数据
.then((data) = > {
console.info(`promise: decrypt data success, data is ` + Uint8ArrayToString(data.outData as Uint8Array));
console.error(`promise: decrypt data failed, ${JSON.stringify(error)}`);
async function DeleteKey() {
* 模拟删除密钥场景
* 1. 获取密钥别名
let emptyOptions: huks.HuksOptions = {
properties: []
* 2. 调用deleteKeyItem删除密钥
await huks.deleteKeyItem(aesKeyAlias, emptyOptions)
.then((data) = > {
console.info(`promise: delete data success`);
console.error(`promise: delete data failed, ${JSON.stringify(error)}`);
