以AES 256密钥为例,完成加解密。具体的场景介绍及支持的算法规格。
target_link_libraries(entry PUBLIC libhuks_ndk.z.so)
生成密钥
gitee.com/li-shizhen-skin/harmony-os/blob/master/README.md]除此之外,开发者也可以参考[密钥导入],导入已有的密钥。
加密
解密
HarmonyOS与OpenHarmony鸿蒙文档籽料:mau123789是v直接拿
删除密钥
当密钥废弃不用时,需要调用OH_Huks_DeleteKeyItem删除密钥。
#include "huks/native_huks_api.h"
#include "huks/native_huks_param.h"
#include < string.h >
OH_Huks_Result InitParamSet(
struct OH_Huks_ParamSet **paramSet,
const struct OH_Huks_Param *params,
uint32_t paramCount)
OH_Huks_Result ret = OH_Huks_InitParamSet(paramSet);
if (ret.errorCode != OH_HUKS_SUCCESS) {
return ret;
ret = OH_Huks_AddParams(*paramSet, params, paramCount);
OH_Huks_FreeParamSet(paramSet);
return ret;
ret = OH_Huks_BuildParamSet(paramSet);
return ret;
return ret;
static const uint32_t IV_SIZE = 16;
static uint8_t IV[IV_SIZE] = { 0 }; // this is a test value, for real use the iv should be different every time
static struct OH_Huks_Param g_genEncDecParams[] = {
.tag = OH_HUKS_TAG_ALGORITHM,
.uint32Param = OH_HUKS_ALG_AES
.tag = OH_HUKS_TAG_PURPOSE,
.uint32Param = OH_HUKS_KEY_PURPOSE_ENCRYPT | OH_HUKS_KEY_PURPOSE_DECRYPT
.tag = OH_HUKS_TAG_KEY_SIZE,
.uint32Param = OH_HUKS_AES_KEY_SIZE_256
.tag = OH_HUKS_TAG_PADDING,
.uint32Param = OH_HUKS_PADDING_NONE
.tag = OH_HUKS_TAG_BLOCK_MODE,
.uint32Param = OH_HUKS_MODE_CBC
static struct OH_Huks_Param g_encryptParams[] = {
.tag = OH_HUKS_TAG_IV,
.blob = {
.size = IV_SIZE,
.data = (uint8_t *)IV // this is a test value, for real use the iv should be different every time
static struct OH_Huks_Param g_decryptParams[] = {
.uint32Param = OH_HUKS_KEY_PURPOSE_DECRYPT
.blob = {
.size = IV_SIZE,
static const uint32_t AES_COMMON_SIZE = 1024;
OH_Huks_Result HksAesCipherTestEncrypt(
const struct OH_Huks_Blob *keyAlias,
const struct OH_Huks_ParamSet *encryptParamSet, const struct OH_Huks_Blob *inData, struct OH_Huks_Blob *cipherText)
uint8_t handleE[sizeof(uint64_t)] = {0};
struct OH_Huks_Blob handleEncrypt = {sizeof(uint64_t), handleE};
OH_Huks_Result ret = OH_Huks_InitSession(keyAlias, encryptParamSet, &handleEncrypt, nullptr);
return ret;
ret = OH_Huks_FinishSession(&handleEncrypt, encryptParamSet, inData, cipherText);
return ret;
OH_Huks_Result HksAesCipherTestDecrypt(
const struct OH_Huks_ParamSet *decryptParamSet, const struct OH_Huks_Blob *cipherText, struct OH_Huks_Blob *plainText,
const struct OH_Huks_Blob *inData)
uint8_t handleD[sizeof(uint64_t)] = {0};
struct OH_Huks_Blob handleDecrypt = {sizeof(uint64_t), handleD};
OH_Huks_Result ret = OH_Huks_InitSession(keyAlias, decryptParamSet, &handleDecrypt, nullptr);
return ret;
ret = OH_Huks_FinishSession(&handleDecrypt, decryptParamSet, cipherText, plainText);
return ret;
static napi_value EncDecKey(napi_env env, napi_callback_info info)
char tmpKeyAlias[] = "test_enc_dec";
struct OH_Huks_Blob keyAlias = { (uint32_t)strlen(tmpKeyAlias), (uint8_t *)tmpKeyAlias };
struct OH_Huks_ParamSet *genParamSet = nullptr;
struct OH_Huks_ParamSet *encryptParamSet = nullptr;
struct OH_Huks_ParamSet *decryptParamSet = nullptr;
OH_Huks_Result ohResult;
do {
/* 1. Generate Key */
* 模拟生成密钥场景
* 1.1. 确定密钥别名
* 1.2. 获取生成密钥算法参数配置
ohResult = InitParamSet(&genParamSet, g_genEncDecParams, sizeof(g_genEncDecParams) / sizeof(OH_Huks_Param));
if (ohResult.errorCode != OH_HUKS_SUCCESS) {
break;
* 1.3. 调用generateKeyItem
ohResult = OH_Huks_GenerateKeyItem(&keyAlias, genParamSet, nullptr);
break;
/* 2. Encrypt */
* 模拟加密场景
* 2.1. 获取密钥别名
* 2.2. 获取待加密的数据
* 2.3. 获取加密算法参数配置
ohResult = InitParamSet(&encryptParamSet, g_encryptParams, sizeof(g_encryptParams) / sizeof(OH_Huks_Param));
break;
char tmpInData[] = "AES_ECB_INDATA_1";
struct OH_Huks_Blob inData = { (uint32_t)strlen(tmpInData), (uint8_t *)tmpInData };
uint8_t cipher[AES_COMMON_SIZE] = {0};
struct OH_Huks_Blob cipherText = {AES_COMMON_SIZE, cipher};
* 2.4. 调用initSession获取handle
* 2.5. 调用finishSession获取加密后的密文
ohResult = HksAesCipherTestEncrypt(&keyAlias, encryptParamSet, &inData, &cipherText);
break;
/* 3. Decrypt */
* 模拟解密场景
* 3.1. 获取密钥别名
* 3.2. 获取待解密的密文
* 3.3. 获取解密算法参数配置
ohResult = InitParamSet(&decryptParamSet, g_decryptParams, sizeof(g_decryptParams) / sizeof(OH_Huks_Param));
break;
uint8_t plain[AES_COMMON_SIZE] = {0};
struct OH_Huks_Blob plainText = {AES_COMMON_SIZE, plain};
* 3.4. 调用initSession获取handle
* 3.5. 调用finishSession获取解密后的数据
ohResult = HksAesCipherTestDecrypt(&keyAlias, decryptParamSet, &cipherText, &plainText, &inData);
} while (0);
/* 4. Delete Key */
* 模拟删除密钥场景
* 4.1. 获取密钥别名
* 4.2. 调用deleteKeyItem删除密钥
(void)OH_Huks_DeleteKeyItem(&keyAlias, genParamSet);
OH_Huks_FreeParamSet(&genParamSet);
OH_Huks_FreeParamSet(&encryptParamSet);
OH_Huks_FreeParamSet(&decryptParamSet);
napi_value ret;
napi_create_int32(env, ohResult.errorCode, &ret);
return ret;
