鸿蒙开发:Universal Keystore Kit 密钥管理服务 非匿名密钥证明ArkTS 电子说
在使用本功能前,需申请权限:ohos.permission.ATTEST_KEY。请开发者根据应用的APL等级,参考具体的操作路径[权限申请]。
`HarmonyOS与OpenHarmony鸿蒙文档籽料:mau123789是v直接拿`
* 以下以attestKey的Promise接口操作验证为例
import { huks } from '@kit.UniversalKeystoreKit';
/* 1.确定密钥别名 */
let keyAliasString = "key attest";
let aliasString = keyAliasString;
let aliasUint8 = StringToUint8Array(keyAliasString);
let securityLevel = StringToUint8Array('sec_level');
let challenge = StringToUint8Array('challenge_data');
let versionInfo = StringToUint8Array('version_info');
let attestCertChain: Array< string >;
class throwObject {
isThrow: boolean = false;
/* 封装生成时的密钥参数集 */
let genKeyProperties: Array< huks.HuksParam > = [
tag: huks.HuksTag.HUKS_TAG_ALGORITHM,
value: huks.HuksKeyAlg.HUKS_ALG_RSA
tag: huks.HuksTag.HUKS_TAG_KEY_SIZE,
value: huks.HuksKeySize.HUKS_RSA_KEY_SIZE_2048
tag: huks.HuksTag.HUKS_TAG_PURPOSE,
value: huks.HuksKeyPurpose.HUKS_KEY_PURPOSE_VERIFY
tag: huks.HuksTag.HUKS_TAG_DIGEST,
value: huks.HuksKeyDigest.HUKS_DIGEST_SHA256
tag: huks.HuksTag.HUKS_TAG_PADDING,
value: huks.HuksKeyPadding.HUKS_PADDING_PSS
tag: huks.HuksTag.HUKS_TAG_KEY_GENERATE_TYPE,
value: huks.HuksKeyGenerateType.HUKS_KEY_GENERATE_TYPE_DEFAULT
tag: huks.HuksTag.HUKS_TAG_BLOCK_MODE,
value: huks.HuksCipherMode.HUKS_MODE_ECB
let genOptions: huks.HuksOptions = {
properties: genKeyProperties
/* 2.封装证明密钥的参数集 */
let attestKeyproperties: Array< huks.HuksParam > = [
tag: huks.HuksTag.HUKS_TAG_ATTESTATION_ID_SEC_LEVEL_INFO,
value: securityLevel
tag: huks.HuksTag.HUKS_TAG_ATTESTATION_CHALLENGE,
value: challenge
tag: huks.HuksTag.HUKS_TAG_ATTESTATION_ID_VERSION_INFO,
value: versionInfo
tag: huks.HuksTag.HUKS_TAG_ATTESTATION_ID_ALIAS,
value: aliasUint8
let huksOptions: huks.HuksOptions = {
properties: attestKeyproperties
function StringToUint8Array(str: string) {
let arr: number[] = [];
for (let i = 0, j = str.length; i < j; ++i) {
arr.push(str.charCodeAt(i));
return new Uint8Array(arr);
function generateKeyItem(keyAlias: string, huksOptions: huks.HuksOptions, throwObject: throwObject) {
return new Promise< void >((resolve, reject) = > {
try {
huks.generateKeyItem(keyAlias, huksOptions, (error, data) = > {
if (error) {
reject(error);
} else {
resolve(data);
} catch (error) {
throwObject.isThrow = true;
throw (error as Error);
/* 3.生成密钥 */
async function publicGenKeyFunc(keyAlias: string, huksOptions: huks.HuksOptions) {
console.info(`enter promise generateKeyItem`);
let throwObject: throwObject = { isThrow: false };
try {
await generateKeyItem(keyAlias, huksOptions, throwObject)
.then((data) = > {
console.info(`promise: generateKeyItem success, data = ${JSON.stringify(data)}`);
.catch((error: Error) = > {
if (throwObject.isThrow) {
} else {
console.error(`promise: generateKeyItem failed, ${JSON.stringify(error)}`);
} catch (error) {
console.error(`promise: generateKeyItem input arg invalid, ${JSON.stringify(error)}`);
/* 4.证明密钥 */
function attestKeyItem(keyAlias: string, huksOptions: huks.HuksOptions, throwObject: throwObject) {
return new Promise< huks.HuksReturnResult >((resolve, reject) = > {
try {
huks.attestKeyItem(keyAlias, huksOptions, (error, data) = > {
if (error) {
reject(error);
} else {
resolve(data);
} catch (error) {
async function publicAttestKey(keyAlias: string, huksOptions: huks.HuksOptions) {
console.info(`enter promise attestKeyItem`);
try {
await attestKeyItem(keyAlias, huksOptions, throwObject)
.then((data) = > {
console.info(`promise: attestKeyItem success, data = ${JSON.stringify(data)}`);
if (data !== null && data.certChains !== null) {
attestCertChain = data.certChains as string[];
} else {
console.error(`promise: attestKeyItem failed, ${JSON.stringify(error)}`);
} catch (error) {
console.error(`promise: attestKeyItem input arg invalid, ${JSON.stringify(error)}`);
async function AttestKeyTest() {
await publicGenKeyFunc(aliasString, genOptions);
await publicAttestKey(aliasString, huksOptions);
console.info('attest certChain data: ' + attestCertChain)
