4016 CMOS 四双向开关
消耗积分:5 | 格式:rar | 大小:94 | 2009-08-08
张涛
分享资料个
The CD4016BC is a quad bilateral switch intended for the
transmission or multiplexing of analog or digital signals. It is
pin-for-pin compatible with CD4066BC.
Features
Wide supply voltage range: 3V to 15V
Wide range of digital and analog switching: ±7.5 VPEAK
“ON” resistance for 15V operation: 400W (typ.)
Matched “ON” resistance over 15V signal input:
DRON = 10W (typ.)
n High degree of linearity:
0.4% distortion (typ.)
@ fIS = 1 kHz, VIS = 5 Vp-p,
VDD-VSS = 10V, RL = 10 kW
n Extremely low “OFF” switch leakage:
0.1 nA (typ.)
@ VDD - VSS = 10V
TA = 25°C
评论(0)
发评论
下载排行榜
