LTC6420 pdf
消耗积分:3 | 格式:rar | 大小:666 | 2008-06-30
敷衍作笑谈
分享资料个
The LTC®6420-20 is a dual high-speed differential amplifi  er
targeted at processing signals from DC to 300MHz. The
part has been specifi  cally designed to drive 12-, 14- and
16-bit ADCs with low noise and low distortion, but can also
be used as a general-purpose broadband gain block.
The LTC6420-20 is easy to use, with minimal support
circuitry required. The output common mode voltage
is set using an external pin, independent of the inputs,
which eliminates the need for transformers or AC-coupling
capacitors in many applications. The gain is internally
fi xed at 20dB (10V/V).
The LTC6420-20 saves space and power compared to
alternative solutions using IF gain blocks and transform-
ers. The LTC6420-20 is packaged in a compact 20-lead
3mm × 4mm QFN package and operates over the –40°C
to 85°C temperature range.
评论(0)
发评论
下载排行榜
