LT3592 pdf
消耗积分:3 | 格式:rar | 大小:666 | 2008-06-30
分享资料个
The LT®3592 is a fi  xed frequency step-down DC/DC con-
verter designed to operate as a constant-current source.
An external sense resistor monitors the output current
allowing accurate current regulation, ideal for driving
high current LEDs. The output current can be dimmed
by a factor of 10 using an external signal for nighttime
brake lights.
The high switching frequency offers several advantages by
permitting the use of a small inductor and small ceramic
capacitors. Small components combined with the LT3592’s
10-pin DFN leadless surface mount package save space and
cost versus alternative solutions. The constant switching
frequency combined with low-impedance ceramic capaci-
tors result in low, predictable output ripple.
A wide input voltage range of 3.6V to 36V makes the
LT3592 useful in a variety of applications. Current mode
PWM architecture provides fast transient response and
cycle-by-cycle current limiting. Thermal shutdown provides
additional protection.
评论(0)
发评论
下载排行榜
