LTM8021 pdf
消耗积分:3 | 格式:rar | 大小:677 | 2008-06-30
分享资料个
The LTM®8021 is a 36VIN 500mA, step-down DC/DC
μModuleTM. Included in the package are the switching
controller, power switches, inductor, and all support compo-
nents. Operating over an input voltage range of 3V to 36V,
the LTM8021 supports an output voltage range of 0.8V to
5V, set by a single resistor. Only an output and bulk input
capacitor are needed to fi nish the design.
The low profi  le package (2.82mm) enables utilization of
unused space on the bottom of PC boards for high den-
sity point of load regulation. A built-in soft-start timer is
adjustable with just a resistor and capacitor.
The LTM8021 is packaged in a thermally enhanced, com-
pact (11.25mm  × 6.25mm) and low profi  le  (2.82mm)
overmolded Land Grid Array (LGA) package suitable for
automated assembly by standard surface mount equip-
ment. The LTM8021 is RoHS compliant.
评论(0)
发评论
下载排行榜
