LTC4110 pdf
消耗积分:3 | 格式:rar | 大小:777 | 2008-06-30
分享资料个
The LTC®4110 is a complete single chip, high effi  ciency,
fl yback battery charge and discharge manager with auto-
matic switchover between the input supply and the backup
battery or super capacitor. The IC provides four modes of
operation: battery backup, battery charge, battery calibra-
tion and shutdown. Battery backup and battery charge are
automatic standalone modes, while the optional calibration
mode requires a CPU host to communicate over an SMBus.
During calibration the fl  yback charger is used in reverse
to discharge the battery with a programmable constant
current into the system load eliminating heat generation.
Three status outputs can be individually reconfi  gured over
the SMBus to become GPIOs. User programmable over-
discharge protection is provided. The SHDN pin isolates
the battery to support shipping the product with a charged
battery installed.
Multiple LTC4110s can be combined to form a redundant
battery backup system or increase the number of battery
packs to achieve longer backup run times.
The LTC4110 is available in a low profi  le (0.75mm), 38-pin
5mm × 7mm QFN package. The QFN features an exposed
metal die mount pad for optimum thermal performance.
评论(0)
发评论
下载排行榜
