FPGA/ASIC技术
声明:本文由电子创新网赛灵思中文社区整理,转载请注明出处并加上原文链接,谢谢!
赛灵思Zynq SoC推出两年来,在嵌入式领域引发了巨大的反响,现在已经广泛应用于工业、医疗和汽车电子领域,而且,Zynq SoC还大量用于SoM(系统模块)中,据安富利高管介绍,安富利的SoM销量很好,它可以大大加速产品的开发,甚至直接用于量产产品中,下面列出了27款赛灵思合作伙伴的 SoM,这些SoM有各种尺寸和形状,采用多种赛灵思Zynq型号,而且板上RAM和ROM都有不同,且有不同类型的I/O口,这些SoM都有链接,点击链接可以获得更详细的配置详信息。
Vendor SOM Zynq Device(s) Interfaces Maximum RAM Maximum Flash microSD Alpha Data ? ADM-XRC-7Z1 ? ? Z-7045 Z-7100 Ethernet, PCIe 512Mbytes of DDR3 SDRAM (PS) + 512 Mbytes 0f DDR3 (PL) 32 Mbytes of QSPI Yes Avnet ? PicoZed ? ? ? Z-7010 Z-7020 Z-7015 Z-7030 Ethernet, USB 2.0 OTG, Proprietary 1Gbyte of DDR3 SDRAM 32Mbytes of QSPI + 4Gbyte eMMC No Avnet ? MicroZed ?? ? Z7010 Ethernet, USB 2.0, USB-UART, Proprietary, PMOD 1Gbyte of DDR3 SDRAM 32Mbytes of QSPI Yes Avnet ? Zynq Mini-Module Plus ? ? ? Z-7045 Z-7100 Ethernet, USB 2.0, USB-UART, Proprietary 1Gbyte of DDR3 SDRAM 32Mbytes of QSPI + 128Mbytes of Parallel Flash Yes DAVE Embedded Systems ? BORA ? ? Z-7010 Z-7020 Ethernet, 2x UART, 2x USB 2.0 OTG, 2x CAN, Proprietary 1Gbyte of DDR3 SDRAM 8, 16, or 32MBytes of SPI 2x SD/MMC DAVE Embedded Systems ? BORA Xpress ? ? ? Z-7015 Z-7030 Ethernet, 2x UART, 2x USB 2.0 OTG, 2x CAN, Proprietary 1Gbyte of DDR3 SDRAM 8, 16MBytes of SPI 2x SD/MMC Enclustra ? Mars ZX3 ? ? ? Z-7020 Ethernet, USB 2.0, CAN, Proprietary 1Gbyte of DDR3 SDRAM 16Mbytes of QSPI + 512MBytes of NAND No Enclustra ? Mercury ZX1 ? ? ? Z-7030 Z-7035 Z-7045 PCIe x4/x8, Ethernet, USB 2.0, 2x UART, 2x CAN, 2x I2C 1Gbyte of DDR3 SDRAM (PS) + 256Mbytes of DDR3 SDRAM (PL) 64Mbytes of QSPI + 512Mbytes of NAND No Enclustra ? Mercury ZX5 ? ? ? Z-7015 Z-7030 PCIe x4, USB 2.0, Ethernet, 2x UART, 2x SPI, 2x CAN, 2x I2C 1Gbyte of DDR3 SDRAM 64Mbytes of QSPI + 512Mbytes of NAND No Ensilica ? eSi-ZM1 ? ?
Z-7020
Ethernet, 4-port USB 2.0 hub, analog, UART, Proprietary
16Mbytes of QSPI + 1Gbyte of NAND
Yes
inrevium
TB-7Z-IAE
Z-7020
2x Ethernet, Proprietary
16Mbytes of QSPI + 64kbits of FRAM
Yes
iVeia
Atlas-I-Z7e
Z-7020
2x USB 2.0, UART, I2C, saudio in/out, keypad matrix, Proprietary
256Mbytes of LPDDR2 SDRAM (PS) + 256Mbytes of LPDDR2 SDRAM (PL)
Yes
iVeia
Atlas-II-Z7x
Z-7030
Z-7045
Ethernet, UART, CAN, I2C, DVI/HDMI, CameraLink, GigE Vision, analog
1Gbyte DDR3 SDRAM (PS) + 512Mbytes DDR3 SDRAM (PL)
4Mbytes of QSPI + 32Gbytes of NAND eMMC
Yes
National Instruments
sbRIO-9651
Z-7020
Ethernet, UART, 2x USB, Proprietary
512Mbytes of NAND
No
sbRIO-9627
Z-7020
2x Ethernet, 2x USB, 6x UART, 2x CAN, 3x RS-485, analog, Proprietary
512Mbytes of NAND
2x SD/SDHC
sbRIO-9637
Z-7020
Ethernet, USB, UART, CAN, RS-485, Proprietary
512Mbytes of NAND
Yes
sbRIO-9607
Z-7020
2x Ethernet, USB, UART, CAN, RS-485, analog, Proprietary
512Mbytes of NAND
No
MYIR Tech Ltd
MYC-C7Z7010/20
Z-7010
Z-7020
Ethernet, USB, Proprietary
32Mbytes of QSPI + 4Gbytes of eMMC
No
MYIR Tech Ltd
Z-turn Board
Z-7010
Z-7020
Ethernet, USB 2.0 OTG, USB-UART, CAN, HDMI, on-board sensors, Proprietary
16Mbytes of QSPI
Yes
SHANGHAI inrevium Solutions Ltd
Zynq PLC SoM
Z-7010
3x Ethernet, CAN, UART, Proprietary
16Mbytes of QSPI
Yes
SoC-e
SMARTZynq
Z-7010
Z-7020
5x Ethernet, Proprietary
8Gbytes of DDR3 SDRAM
32Mbytes of QSPI
Yes
Topic
MIAMI
Z-7015
Z-7030
PCIe 4x, Ethernet, USB 2.0 OTG, UART, CAN, I2C, SATA3, Proprietary
512Mbytes of DDR3L SDRAM
32Mbytes of QSPI + 256Mbytes of NAND
No
Trenz
TE0715 Zynq
Z-7015
Z-7030
Ethernet, USB 2.0, Proprietary
1Gbyte DDR3 SDRAM
32Mbytes of QSPI
No
Trenz
TE0720 Zynq
Z-7020
1Gbyte DDR3 SDRAM
32Mbytes of QSPI + 64Gbytes of eMMC
No
Trenz
TE0728 Zynq Automotive
Z-7020
2x 100M Ethernet, CAN, Proprietary
16Mbytes of QSPI
No
V3 Technology, Ltd
SNOWLeo
Z-7010
Z-7020
Ethernet, UART, USB 2.0 OTG, HDMI, CMOS Sensor, PMOD, Proprietary
4Gbytes of NAND
Yes
V3 Technology, Ltd
ZingSoM2
Z-7010
Z-7020
16Gbytes of NAND
No
当然,这个表格不一定最完整的,我们会不断补充完整,请注意收藏本页,另外,在表格下方是我们目前可以提供的Microzed SoM信息,只要RMB1588元就可以买到,我们有现货,是安富利原装正品。
