FPGA verilog实现的1602时钟计数器
FPGA/ASIC技术
211人已加入
原文链接:熬夜到了1点了,终于写出了1602的时钟计数器代码。为什么是时钟计数器呢?因为我还没来得及做校准时间,所以只能称之为时钟计数器,不能成为电子钟。网上很少用人公开这一类代码,一搜FPGA  1602,都是写一个静态的显示,在实际应用中,是没有用的,因此这个简单的例子,给大家抛砖引玉了!上代码: Qii 9.0编译过,21EDA 开发板测试OKmodule LCD  (  rst,  key1,  clk,  rw,  rs,  en,  data ); input clk,rst,key1; output rs,en,rw; output [7:0] data;  reg rs,en_sel; reg [7:0] data; reg [7:0] shi,fen,miao; reg [31:0]count,count1;  //LCD CLK 分频计数器 reg lcd_clk; reg [7:0] one_1,one_2,one_3,one_4,one_5,one_6,one_7,one_8,one_9,one_10,one_11,one_12,one_13,one_14,one_15,one_16; reg [7:0] two_1,two_2,two_3,two_4,two_5,two_6,two_7,two_8,two_9,two_10,two_11,two_12,two_13,two_14,two_15,two_16; reg [7:0] next,xianshi,two; parameter state0  =8'h00,     //设置8位格式,2行,5*7    8'h38;     state1  =8'h01,  //整体显示,关光标,不闪烁  8'h0C    闪烁 8'h0e    state2  =8'h02,  //设定输入方式,增量不移位 8'h06    state3  =8'h03,  //清除显示     8'h01    state4  =8'h04,  //显示第一行的指令  80H    state5  =8'h05,  //显示第二行的指令  80H+40H        scan =8'h06,      nul  =8'h07;   parameter data0  =8'h10,   //2行,共32个数据    data1  =8'h11,    data2  =8'h12,    data3  =8'h13,    data4  =8'h14,    data5  =8'h15,    data6  =8'h16,    data7  =8'h17,    data8  =8'h18,    data9  =8'h19,    data10  =8'h20,    data11  =8'h21,    data12  =8'h22,    data13  =8'h23,    data14  =8'h24,    data15  =8'h25,    data16  =8'h26,    data17 =8'h27,    data18 =8'h28,    data19 =8'h29,    data20 =8'h30,    data21  =8'h31,    data22  =8'h32,    data23  =8'h33,    data24  =8'h34,    data25  =8'h35,    data26  =8'h36,    data27  =8'h37,    data28  =8'h38,    data29  =8'h39,    data30  =8'h40,    data31  =8'h41; initial           //初始值 begin   //第一行显示 TEL:13868160569   one_1<="T"; one_2<="E"; one_3<="L"; one_4<=":"; one_5<="1"; one_6<="3"; one_7<="8"; one_8<="6";    one_9<="8";one_10<="1";one_11<="6";one_12<="0";one_13<="5";one_14<="6";one_15<="9";one_16<=" ";   //第二行显示 Clock:00-00-00   two_1<="C"; two_2<="l"; two_3<="o"; two_4<="c"; two_5<="k"; two_6<=":"; two_7<=" "; two_8<=" ";    two_9<="-";two_10<=" ";two_11<=" ";two_12<="-";two_13<=" ";two_14<=" ";two_15<=" ";two_16<=" ";       shi<=0;fen<=0;miao<=0; end     always @(posedge clk )   //获得LCD时钟 begin  count<=count+1;  if(count==250000)  begin   count<=0;   lcd_clk<=~lcd_clk;  end end always @(posedge clk or negedge rst )   //时钟计数器 begin  if(!rst)  begin   shi<=0;fen<=0;miao<=0;   count1<=0;  end  else  begin   en_sel<=1;      two_7<= (shi/10)+8'b00110000;   two_8<= (shi%10)+8'b00110000;   two_10<=(fen/10)+8'b00110000;   two_11<=(fen%10)+8'b00110000;   two_13<=(miao/10)+8'b00110000;   two_14<=(miao%10)+8'b00110000;      count1<=count1+1'b1;   if(count1==49999999)    // 时钟计数   begin    count1<=0;    miao<=miao+1;    if(miao==59)    begin     miao<=0;     fen<=fen+1;     if(fen==59)     begin      fen<=0;      shi<=shi+1;      if(shi==23)      begin       shi<=0;      end     end    end   end  end    end  always @(posedge lcd_clk  ) begin   case(next)    state0 :     begin rs<=0; data<=8'h38; next<=state1; end       //配置液晶    state1 :     begin rs<=0; data<=8'h0e; next<=state2; end    state2 :     begin rs<=0; data<=8'h06; next<=state3; end    state3 :     begin rs<=0; data<=8'h01; next<=state4; end              state4 :     begin rs<=0; data<=8'h80; next<=data0; end //显示第一行    data0 :     begin rs<=1; data<=one_1; next<=data1 ; end    data1 :     begin rs<=1; data<=one_2; next<=data2 ; end    data2 :     begin rs<=1; data<=one_3; next<=data3 ; end    data3 :     begin rs<=1; data<=one_4; next<=data4 ; end    data4 :     begin rs<=1; data<=one_5; next<=data5 ; end    data5 :     begin rs<=1; data<=one_6; next<=data6 ; end    data6 :     begin rs<=1; data<=one_7; next<=data7 ; end    data7 :     begin rs<=1; data<=one_8; next<=data8 ; end    data8 :     begin rs<=1; data<=one_9; next<=data9 ; end    data9 :     begin rs<=1; data<=one_10; next<=data10 ; end    data10 :     begin rs<=1; data<=one_11; next<=data11 ; end    data11 :     begin rs<=1; data<=one_12; next<=data12 ; end    data12 :     begin rs<=1; data<=one_13; next<=data13 ; end    data13 :     begin rs<=1; data<=one_14; next<=data14 ; end    data14 :     begin rs<=1; data<=one_15; next<=data15 ; end    data15 :     begin rs<=1; data<=one_16; next<=state5 ; end          state5:        begin rs<=0;data<=8'hC0; next<=data16; end //显示第二行    data16 :     begin rs<=1; data<=two_1; next<=data17 ; end    data17 :     begin rs<=1; data<=two_2; next<=data18 ; end    data18 :     begin rs<=1; data<=two_3; next<=data19 ; end    data19 :     begin rs<=1; data<=two_4; next<=data20 ; end    data20 :     begin rs<=1; data<=two_5; next<=data21 ; end    data21 :     begin rs<=1; data<=two_6; next<=data22 ; end    data22 :     begin rs<=1; data<=two_7; next<=data23 ; end    data23 :     begin rs<=1; data<=two_8; next<=data24 ; end    data24 :     begin rs<=1; data<=two_9; next<=data25 ; end    data25 :     begin rs<=1; data<=two_10; next<=data26 ; end    data26 :     begin rs<=1; data<=two_11; next<=data27 ; end    data27 :     begin rs<=1; data<=two_12; next<=data28 ; end    data28 :     begin rs<=1; data<=two_13; next<=data29 ; end    data29 :     begin rs<=1; data<=two_14; next<=data30 ; end    data30 :     begin rs<=1; data<=two_15; next<=data31 ; end    data31 :     begin rs<=1; data<=two_16; next<=scan ; end         scan :   //交替更新第一行和第二行数据          begin      next<=state4;     end    default:   next<=state0;    endcase end assign en=lcd_clk && en_sel; assign rw=0;endmodule
