Features • Atheros XSPAN family chipset • IEEE 802.11n compliant and backward compatible with 802.11b/g • 2.4GHz Single-band 2 x 2 MIMO spatial multiplexing technique • Maximum output power 23dBm@802.11b/g -26dBm MIMO aggregate • Supports up to 300Mbps physical data rates • Delivers up to 10 times the throughput and nearly twice the range of legacy 802.11b/g networks • Transmission Power Control (IEEE 802.11h TPC) • Supports spatial multiplexing and maximal ratio combining (MRC) • Multi-Country Roaming Supported (IEEE802.11d Global Harmonization Standard) • 2 x U.FL Antenna Connector • Complaint with PCI-Express Mini Card 1.1 Standard • Supports 802.11x authentication, 64/128/152Bit WEP,IEEE802.11i encryption
