单片机点亮第一个灯
51 MACRO ASSEMBLER STARTUP 10/23/2015 18:56:56 PAGE 1
MACRO ASSEMBLER A51 V8.01
OBJECT MODULE PLACED IN STARTUP.OBJ
ASSEMBLER INVOKED BY: E:\Keil\C51\BIN\A51.EXE STARTUP.A51 SET(SMALL) DEBUG EP
LOC OBJ LINE SOURCE
1 $nomod51
2 ;------------------------------------------------------------------------------
3 ; This file is part of the C51 Compiler package
4 ; Copyright (c) 1988-2005 Keil Elektronik GmbH and Keil Software, Inc.
5 ; Version 8.01
6 ;
7 ; *** <<< Use Configuration Wizard in Context Menu >>> ***
8 ;------------------------------------------------------------------------------
9 ; STARTUP.A51: This code is executed after processor reset.
10 ;
11 ; To translate this file use A51 with the following invocation:
12 ;
13 ; A51 STARTUP.A51
14 ;
15 ; To link the modified STARTUP.OBJ file to your application use the following
16 ; Lx51 invocation:
17 ;
18 ; Lx51 your object file list, STARTUP.OBJ controls
19 ;
20 ;------------------------------------------------------------------------------
21 ;
22 ; User-defined Power-On Initialization of Memory
23 ;
24 ; With the following EQU statements the initialization of memory
25 ; at processor reset can be defined:
26 ;
27 ; IDATALEN: IDATA memory size <0x0-0x100>
28 ; Note: The absolute start-address of IDATA memory is always 0
29 ; The IDATA space overlaps physically the DATA and BIT areas.
0080 30 IDATALEN EQU 80H
31 ;
32 ; XDATASTART: XDATA memory start address <0x0-0xFFFF>
33 ; The absolute start address of XDATA memory
0000 34 XDATASTART EQU 0
35 ;
36 ; XDATALEN: XDATA memory size <0x0-0xFFFF>
37 ; The length of XDATA memory in bytes.
0000 38 XDATALEN EQU 0
39 ;
40 ; PDATASTART: PDATA memory start address <0x0-0xFFFF>
41 ; The absolute start address of PDATA memory
0000 42 PDATASTART EQU 0H
43 ;
44 ; PDATALEN: PDATA memory size <0x0-0xFF>
45 ; The length of PDATA memory in bytes.
0000 46 PDATALEN EQU 0H
47 ;
48 ;
49 ;------------------------------------------------------------------------------
50 ;
