浪涌电流变换器的管理
在现代开关直流变换器的设计中,电容器的喷射会导致模块启动时高的浪涌电流。除了元件损坏和系统故障的风险外,这种浪涌电流也会给那些在便携式产品中最大限度地延长电池寿命的工程师带来麻烦。
本文介绍了为什么在浪涌电流发生,它如何危及电池寿命,以及制造商的步骤,现代功率模块已经采取了限制问题。
什么是潮流?
开关DC / DC转换器通常具有多个电容器。例如,一个设备构成电磁干扰(EMI)输入滤波器的一部分,设计用来限制输入回路中的电流产生的干扰(图1),而另一个装置位于输出侧以限制电压纹波。
Figure 1: Schematic of low pass input EMI filter between primary power source and switching regulator. The capacitors charge up during startup causing high in-rush current (Courtesy of Texas Instruments)。
When the converter is first switched on, these uncharged capacitors act as virtual short circuits, allowing the current to rapidly escalate. The current spike lasts only as long as it takes the various capacitors to charge, but it can reach a peak value well in excess of what the converter would otherwise experience, even under full load. The only characteristics that limit the magnitude of the spike are the line impedance and the capacitors’ equivalent series resistance (ESR)。
