* @file core_cm3.h
* @brief CMSIS Cortex-M3 Core Peripheral Access Layer Header File
* @version V1.30
* @date 30. October 2009
* @note
* Copyright (C) 2009 ARM Limited. All rights reserved.
* @par
* ARM Limited (ARM) is supplying this software for use with Cortex-M
* processor based microcontrollers. This file can be freely distributed
* within development tools that are supporting such ARM based processors.
* @par
* THIS SOFTWARE IS PROVIDED “AS IS”。 NO WARRANTIES, WHETHER EXPRESS, IMPLIED
* OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE.
* ARM SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR
* CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
#ifndef __CM3_CORE_H__
#define __CM3_CORE_H__
/** @addtogroup CMSIS_CM3_core_LintCinfiguration CMSIS CM3 Core Lint Configuration
* List of Lint messages which will be suppressed and not shown:
* - Error 10: \n
* register uint32_t __regBasePri __asm(“basepri”); \n
* Error 10: Expecting ‘;’
* - Error 530: \n
* return(__regBasePri); \n
* Warning 530: Symbol ‘__regBasePri’ (line 264) not initialized
* - Error 550: \n
* __regBasePri = (basePri & 0x1ff); \n
* Warning 550: Symbol ‘__regBasePri’ (line 271) not accessed
* - Error 754: \n
* uint32_t RESERVED0[24]; \n
* Info 754: local structure member ‘《some, not used in the HAL》’ (line 109, file 。/cm3_core.h) not referenced
* - Error 750: \n
* #define __CM3_CORE_H__ \n
* Info 750: local macro ‘__CM3_CORE_H__’ (line 43, file./cm3_core.h) not referenced
* - Error 528: \n
* static __INLINE void NVIC_DisableIRQ(uint32_t IRQn) \n
* Warning 528: Symbol ‘NVIC_DisableIRQ(unsigned int)’ (line 419, file 。/cm3_core.h) not referenced
* - Error 751: \n
* } InterruptType_Type; \n
* Info 751: local typedef ‘InterruptType_Type’ (line 170, file 。/cm3_core.h) not referenced
* Note: To re-enable a Message, insert a space before ‘lint’ *
