安全的微控制器保持数据安全
安全的MCU产品从8位到32位CPU不等,有专用加密引擎、随机数生成器和额外的功能,以确保通信通道和受保护的数据。
在这个互联网时代,身份盗窃、知识产权保护、金融账户和支付保护是消费者和设计师所关心的问题。为了保证一切安全,许多系统都采用安全措施,如数据加密和物理屏蔽,以防止黑客和其他恶意活动访问数据、财务信息,甚至知识产权。即使是简单的汽车门钥匙/点火钥匙也变得更加安全,嵌入式处理器运行挑战和响应身份验证,以防止车辆盗窃。此外,运动到“漂亮”的电网也将升级为保密通信需求防止黑客或***造成对电网的破坏。
虽然通用嵌入式处理器进行数据的加密和解密,计算密集型的要求,如加密标准DES(数据加密标准)、AES(高级加密标准),椭圆曲线,SHA-1(安全散列算法),和其他人可以停滞不前处理器和降低整体的交易。加快先进处理器的计算,英特尔增加新的指令来加速AES加密和解密,以及AES伽罗瓦计数器模式(AES-GCM)认证加密。当在多GHz速度运行时,这些处理器可以提供与专用加密解决方案相媲美的性能。
However, power consumption for a desktop-class Intel i3, i5, i7 or Xeon-class processor could hit 50 W or more. Such a solution is not practical for embedded systems that run constantly, have limited cooling capabilities, and require milliwatt power consumption levels.
In past years, to speed up the computations, separate data-encryption chips have been implemented, but the connection between the processor and the encryption chip is a good target for hackers. To prevent hackers from accessing the connections between chips, designers enclosed the board in a metal shield and included tamper sensors that erased the data and encryption keys if any tampering was detected.
