汽车用降压开关调节器A7986A
消耗积分:0 | 格式:rar | 大小:1.40 MB | 2017-09-01
分享资料个
  Description The A7986A is a step-down switching regulator with a 3.7 A (min.) current limited embedded power MOSFET, so it is able to deliver up to 3 A current to the load depending on the application conditions. The input voltage can range from 4.5 V to 38 V, while the output voltage can be set starting from 0.6 V to VIN. Requiring a minimum set of external components, the device includes an internal 250 kHz switching frequency oscillator that can be externally adjusted up to 1 MHz. The HSOP8 package with exposed pad allows the reduction of Rth(JA) down to 40 °C/W.
汽车用降压开关调节器A7986A
评论(0)
发评论
下载排行榜
