利用C程序实现音乐点唱功能及几种案例分享
消耗积分:0 | 格式:rar | 大小:0.15 MB | 2017-09-06
分享资料个
1、快乐点唱机实验
/* ch09-5-4.c_ 快乐点唱机实验 */
#include
sbit  buzzer = P3^7;   // 声明输出端
unsigned char  keys,i;   // 声明按钮及播放谱变量
unsigned char  tone_H, tone_L; // 声明计时量变量
void  beat_125(unsigned char); // 声明节拍函数
unsigned char code song1[]={ 1, 1, 2, 1,  4, 3,  1, 1, 2, 1,  5, 4,
        1, 1, 8, 6,  4, 3, 2,  11, 11, 6, 4,  5, 4,  15 };
unsigned char code beat1[]={ 4, 4, 8, 8,  8, 16,  4, 4, 8, 8,  8, 16,
        4, 4, 8, 8,  8, 8, 8,  4, 4, 8, 8,  8, 16 };
unsigned char code song2[]={ 1, 1, 1,  3, 2, 1,  3, 3, 3,  5, 4, 3,  5, 4, 3,  2,
        2, 1, 0,  1, 2, 3,  4, 3, 2,  3, 4, 5,  5, 4, 3, 2,  1, 15};
unsigned char code beat2[]={ 4, 4, 4,  6, 2, 4,  4, 4, 4,  6, 2, 4,  4, 4, 4,  12 ,
          8, 2, 2,  4, 4, 4,  8, 2, 2,  4, 4, 4,  2, 2, 4, 4,  12 };
unsigned char code song3[]={ 8, 7, 6, 5, 5,  6, 8, 5,  6, 5, 3, 2, 5,  3, 12,
          8, 7, 6, 5, 5,  6, 8, 5,  6, 5, 3, 2, 5,  1, 12,
          2, 3, 2, 5,   6, 5, 6, 8,   9, 8, 7, 6, 9,  5, 12,
          6, 8, 5, 6,  3, 5, 6, 5, 3,  2, 3, 5, 3, 2,  1, 0,  15 };
unsigned char code beat3[]={ 8, 4, 4, 8, 8,  8, 8, 16,  8, 4, 4, 8, 8,  24, 8,
        8, 4, 4, 16,  8, 4, 4, 16,  8, 4, 4, 8, 8,  24, 8,
        8, 8, 8, 8,  8, 4, 4, 8, 8,  8, 4, 4, 8, 8,  24, 8 };
unsigned char code song4[]={ 2, 2, 3, 5,  6, 5, 6, 7,  9, 7, 7, 6, 5,  6,
        7, 9, 9, 7, 9,  5, 6, 6,  2, 7, 7, 6, 5,  5,
        6, 6, 7, 6, 5,  3, 2, 3, 5,  3, 5, 6, 7,  9,
        9, 9, 10, 9, 7,  7, 6, 5, 3,  2, 7, 7, 6, 5,  5,  15};
unsigned char code beat4[]={ 12, 4, 8, 8,  8, 4, 4, 16,  12, 4, 4, 4, 8,  32,
        12, 4, 8, 4, 4,  12, 4, 16,  12, 4, 8, 4, 4,  32,
        12, 4, 8, 4, 4,  8, 4, 4, 16,  12, 8, 8, 8,  32,
        12, 4, 8, 4, 4,  8, 4, 4, 16,  12, 4, 8, 4, 4,  32  };
unsigned int code tone[]={ 1012, 956, 852, 759, 716, 638,
       568, 506, 478, 426, 379,531, 10 };//音阶定义
void play1(void);     // 声明play1函数
void play2(void);     // 声明play2函数
void play3(void);     // 声明play3函数
void play4(void);     // 声明play4函数
main()
{ buzzer=1;     // 蜂 器初始值
 IE=0x82;      // 启用Timer 0
 TMOD=0x01;         // 设定MODE1
 while (1)     // while循环
 { P2=0xff;    // 将Port2规划为输入埠
  keys=~P2;    // 读取按钮
  switch (keys)   // 判读
  { case 0x01: play1(); break; // 按下S1,播放第一首歌
   case 0x02: play2(); break; // 按下S2,播放第二首歌
   case 0x04: play3(); break; // 按下S3,播放第三首歌
   case 0x08: play4(); break; // 按下S4,播放第四首歌
  }  buzzer=1;   // 蜂 器不动作
 }       // while循环结束
}        // 主程序结束
//==第一首歌=================================
void play1(void)
{ i=0;
 while(song1[i]!=15)   // while循环开始
 { tone_H=(65536-tone[song1[i]])/256;// 读取音阶计数量之高八位元
  tone_L=(65536-tone[song1[i]])%256;// 读取音阶计数量之低八位元
  TH0=tone_H;    // 填入音阶计数量之高八位元
  TL0=tone_L;    // 填入音阶计数量之低八位元
  TR0=1;     // 启动Timer 0
  beat_125(beat1[i]);  // 指定节拍
  i++;     // 下一个音
  TR0=0;     // 关闭Timer 0
 }       // 结束播放
//==第二首歌=================================
void play2(void)
{ i=0;
 while(song2[i]!=15)   // while循环开始
 { tone_H=(65536-tone[song2[i]])/256;// 读取音阶计数量之高八位元
  tone_L=(65536-tone[song2[i]])%256;// 读取音阶计数量之低八位元
  TR0=1;     // 启动Timer 0
  beat_125(beat2[i]);  // 指定节拍
  i++;     // 下一个音
  TR0=0;     // 关闭Timer 0
}        // 结束播放
//==第三首歌=================================
void play3(void)
{ i=0;
 while(song3[i]!=15)   // while循环开始
 { tone_H=(65536-tone[song3[i]])/256;// 读取音阶计数量之高八位元
  tone_L=(65536-tone[song3[i]])%256;// 读取音阶计数量之低八位元
  TR0=1;     // 启动Timer 0
  beat_125(beat3[i]);  // 指定节拍
  i++;     // 下一个音
  TR0=0;     // 关闭Timer 0
}        // 结束播放
//==第四首歌=================================
void play4(void)
{ i=0;
 while(song4[i]!=15)   // while循环开始
 { tone_H=(65536-tone[song4[i]])/256;// 读取音阶计数量之高八位元
  tone_L=(65536-tone[song4[i]])%256;// 读取音阶计数量之低八位元
  TR0=1;     // 启动Timer 0
  beat_125(beat4[i]);  // 指定节拍
  i++;     // 下一个音
  TR0=0;     // 关闭Timer 0
}        // 结束播放
//====Timer 0中断子程序==================
void tone_timer(void) interrupt 1 // Timer 0中断子程序开始
{ TH0=tone_H;     // 填入计时量之高八位元
 TL0=tone_L;     // 填入计时量之低八位元
 buzzer=~buzzer;    // 蜂 器反相输出
}        // 结束中断子程序
//====节拍函数==================
void beat_125(unsigned char x) // 节拍函数开始
{ unsigned char i,j,k;  // 声明变量
 for (i=0;i   for (j=0;j<125;j++)  // j循环
   for (k=0;k<120;k++);// k循环
}        // 结束节拍函数
2、生日快乐歌实验
/* 生日快乐歌实验(ch09-5-3.c) */
#include
unsigned char  i=0;    // 声明变量
unsigned char code song[]={ 1, 1, 2, 1,  4, 3,  1, 1, 2, 1,  5, 4,
       1, 1, 8, 6,  4, 3, 2,  11, 11, 6, 4,  5, 4,  15};//歌曲
unsigned char code beat[]={ 4, 4, 8, 8,  8, 16,  4, 4, 8, 8,  8, 16,
       4, 4, 8, 8,  8, 8, 8,  4, 4, 8, 8,  8, 16};  //节拍
unsigned int code tone[]={ 1012, 956, 852, 759, 716, 638,      // 中音Si ̄So
       568, 506, 478, 426, 379, 536, 10 };    //音阶定义
// ========主程式 ===============
main()
{ buzzer=1;   // 蜂鸣器初始值
 while(song[i]!=15) // while循环开始
 { TH0=tone_H=(65536-tone[song[i]])/256; //填入音阶计数量之高八位元
  TL0= tone_L=(65536-tone[song[i]]) % 256;//填入音阶计数量之低八位元
  TR0=1;   // 启动Timer 0
  beat_125(beat[i]); // 指定节拍
  i++;   // 下一个音
  TR0=0;   // 关闭T0停止播放
  buzzer=1;  // 蜂鸣器不动作
 }     // 结束播放
}      // 主程式结束
//====Timer 0中断副程式==================
void tone_timer(void) interrupt 1 // Timer 0中断副程式开始
}      // 结束中断副程式
   for (k=0;k<120;k++); // k循环
}         // 结束节拍函数
评论(0)
发评论
下载排行榜
