高亮度led驱动芯片AN30888B-VB
消耗积分:0 | 格式:rar | 大小:0.45 MB | 2017-09-11
分享资料个
  AN30888B is a Boost / Buck-Boost / Buck DCDC controller that drives an external power NMOS switch. It is suitable for driving
   Battery operation : 3 V to 15 V  Output current range : 0 A to a few Amperes depending on rating of external NMOS and mode of operation  Current mode control architecture  LED dimming function available by using PWM signal  32 mV / 202 mV reference voltage  Low standby current  Configurable as either Boost / Buck-Boost / Buck mode converter  Built-in various protection circuit : Under voltage lock out Over voltage protection Soft start function  16 pin Plastic Quad Flat Non-leaded Package (QFN Type)
评论(0)
发评论
下载排行榜
