mb9b560l系列32位ARM®皮质®m4f FM4单片机
消耗积分:0 | 格式:rar | 大小:2.43 MB | 2017-09-18
分享资料个
  Devices in the MB9B560L Series are highly integrated 32-bit microcontrollers with high performance and competitive cost. This series is based on the ARM® Cortex® -M4F Processor with on-chip Flash memory and SRAM. The series has peripheral functions such as Motor Control Timers, ADCs and Communication Interfaces (USB, CAN, UART, CSIO, I2C, LIN)。
  The number after the underscore (“_”) in pin names such as XXX_1 and XXX_2 indicates the relocated port number. For these pins, there are multiple pins that provide the same function for the same channel. Use the extended port function register (EPFR) to select the pin.
评论(0)
发评论
下载排行榜
