• Dual issue, 32-bit CPU core complex (e200z7) – Compliant with the Power Architecture® embedded category – 16 KB I-Cache and 16 KB D-Cache – Includes an instruction set enhancement allowing variable length encoding (VLE), optional encoding of mixed 16-bit and 32-bit instructions, for code size footprint reduction – Includes signal processing extension (SPE2) instruction support for digital signal processing (DSP) and single-precision floating point operations • 4 MB on-chip flash – Supports read during program and erase operations, and multiple blocks allowing EEPROM emulation • 256 KB on-chip general-purpose SRAM including 32 KB of standby RAM • Two direct memory access controller (eDMA2) blocks – One supporting 64 channels – One supporting 32 channels • Interrupt controller (INTC) • Frequency modulated phase-locked loop (FMPLL) • Crossbar switch architecture for concurrent access to peripherals, flash, or RAM from multiple bus masters • External bus interface (EBI) for calibration and application development (not available on all packages) • System integration unit (SIU) • Error correction status module (ECSM) • Boot assist module (BAM) supports serial bootload via CAN or SCI • Two second-generation enhanced time processor units (eTPU2) that share code and data RAM. – 32 standard channels per eTPU2 – 24 KB code RAM – 6 KB parameter (data) RAM • Enhanced modular input output system supporting 32 unified channels (eMIOS) with each channel capable of
